PT 9 and Lightbridge
Two simple (I think) questions:
Does PT 9 work with the Lightbridge on a windows system? On such a system, can you record from all 32 Lightbridge inputs simultaneously?
Paul Tumolo Wildplum Recordings a micro label, studio and remote recording service |
Re: PT 9 and Lightbridge
Yes and yes.
I am trying to get a Lightbridge set up and am having problems routing aything out of the analog outs, which show up as 35-36 in pro tools.No trouble recording or outputing on any of the lightpipe I/O.
I am able to get audio out directly from windows. Pro tools 9 maudio profire lightbridge |
It looks like I can only output to the first 32 outputs that are listed. Outputs 33-36 will not function.
I think the max I/O you can have in PT9 is 32. Unless you have HD.
I don't need that many outs, I just can't select anything higher than 32. If I want to just use 2 outs... and they are labeled 33 and 34 I can't use them. Seems like a design flaw, Makes me angry. Makes me want to scream to the world not to buy Pro Tools! This interface is on the compatibility list... but I guess they just don't want you to be able to use the analog outs with their software and their hardware.
You can set the SPDIF I/O first, then ADAT in the Lightbridge driver applet, then have analog output mirror SPDIF (Output 1 & 2 will be SPDIF/Analog out). You will lose the last two ADAT channels (maybe last 8), this is how I read it in the manual as I won't have my Lightbridge for a couple of weeks. You could also just disable the last 8 ADAT I/O which would put the SPDIF at 25-26 and the Analog at 27-28 if you need them separate. Should work either way though. Hope this helps!
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
PT 9 / Lightbridge | XsuspendedX | macOS | 0 | 03-05-2011 11:39 AM |
Help with Lightbridge and PT8 | tekis | Pro Tools M-Powered (Mac) | 0 | 07-16-2009 03:00 PM |
lightbridge not right | therecordinghouse | Pro Tools M-Powered (Mac) | 5 | 12-29-2008 06:14 PM |
lightbridge at 96k? | therecordinghouse | Pro Tools M-Powered (Mac) | 0 | 08-20-2007 10:39 AM |
PT using Lightbridge | sightminer | Pro Tools M-Powered (Mac) | 1 | 05-15-2007 02:21 PM |
