Old 12-04-2000, 08:27 PM
saltminer saltminer is offline
Default Direct Connect - DISCONNECTING BUG
I'm using Direct Connect to get Unity DS-1 into ProTools 5.0.1. The system works pretty well in general, but the plugins of Direct Connect can get "lost".
I might have four inputs, each with a Direct Connect plugin, monitoring channels 1 thru 4 of Unity. At random, these plugins get confused and monitor something different - audio from 4 arrives at input 2, and so on. The plugin displays that it is monitoring 2, but still provides audio from 4. I have to manually reset each one to make it work properly.
I'm using the latest versions of all software. Opening the session gives me "lost" plugins virtually all the time.
Digi, is it your fault or Bitheadz?
saltminer.
Old 12-05-2000, 09:45 AM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
Default Re: Direct Connect - DISCONNECTING BUG
Digi Please check this out before 5.1 release! I have a similar problem. When opening a session that has DC & Unity ,it does communicate until I open OMS and do a test on Unity. Then I close OMS. Unity then works. I have the MOTU 1.15b1 extension and still does not help!
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-06-2000, 06:01 AM
DigiTechSupt's Avatar
saltminer,
As far as I know, is the first report of this behavior. I will be attempting to reproduce this behavior, but I don't know if my 160MB RAM will give me enough "breathing room" for both applications. In the meantime, please post the following:
What version of DirectConnect?
What Computer?
What Mac OS?
How Much RAM?
MARVINBASS,
Although I am using the serial version of the MOTU MIDIExpress XT, I have not yet experienced this behavior. Maybe someone else who is running a MOTU USB interface will read this and post similar behavior.
-BTW, I am running OMS 2.3.8 and FreeMidi 1.45 ("use OMS when available" option checked in the FreeMidi preferences).
Brent
[This message has been edited by DigiTechSupt (edited December 06, 2000).]
Avid Audio Tech Support
Support FAQ
Old 12-06-2000, 11:14 AM
MARVINBASS's Avatar
Hi Brent! I'm running: G4/400(1gig ethernet) 512Ram,OS 9.0.4, PT5.0.1,DAE 5.0.1cs3,OMS 2.3.8, Free Midi 1.45, Magma 7 slot :Mix core,3 Mix Farms,1 Farm, Unity v2.1.0* This may be a USB problem w/ the latest G4's* Please investigate! (FYI: another odd thing, is that ocassionally, the G4 will not shut down with the MTP/AV connected. It will just restart again. I have to unplug the USB cable to get it to shut down) Previous G4 did not do this.
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-11-2000, 01:28 PM
Bryan Bryan is offline
Marvinbass-
The usb problem is just that...a usb problem. Are there new drivers for you midi box? Our G4 does that is we have anything except the usb keyboard hooked up.
I TOO EXPERIENCE THE UNITY/DIRECT CONNECT DISCONNECT BUG on a regular basis.
Biege G3/512 ram/mac os 8.6/pt5.0.1/magma with 3 mix cards and 3 samplecell II cards.
Old 12-12-2000, 12:39 AM
MARVINBASS's Avatar
Yo Brent! Please test on a G4(Gig ethernet).
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 12-12-2000, 02:36 PM
Hi Digi,
my version of Direct Connect is 1.0.1. All ProTools parts are off the 5.0.1 CD. I'm running a Mac dual processor G4/500, OS 9.0.4. Version of Unity is 2.1 (the latest).
Thanks for looking into it.
saltminer
Old 12-13-2000, 05:48 AM
saltminer and others,
-I have been both following this thread and trying to reproduce this behavior on my machine. Up until this point, I have not been able to reproduce this problem (mixed up audio through different instantiations of DC).
-However, I must admit that my tests have not been that complex. Since I am running a system with only 160MB RAM, I am not sure if my problems are happening as a result of having insufficient RAM:
-I can get one instantiation of Unity going without problems (MIDI track triggering channel 1 of Unity and a stereo Aux with Unity stereo 1 output).
-Add another MIDI/Aux track combo (Unity channel 2 with stereo out 2 selected) and choose a patch, as soon as I go into record communication between PT and Unity for channel 2 is cut off (MIDI data is still recorded in PT, but no audio). Channel 1 is still fine.
-When I stop recording and play back the session both patches from Unity will be triggered (but not always).
-Has anyone else had silimar behavior?
-Maybe someone can post their workflow?
Brent
Support FAQ
Old 12-13-2000, 02:55 PM
Sometimes Unity seems to semi-crash, or some part of the multi-processor intelligence in the Mac goes whacko, to suddenly limit Unity to only 3 voices. I have to restart to get things going properly again. I normally can run about 48 voices (not that I try that often).
I've been using Logic synced to ProTools to provide my Midi for Unity, sending it direct and not via OMS. I've not experienced the problems you mention.
saltminer.
Old 12-15-2000, 01:14 AM
MARVINBASS's Avatar
Brent, If you notice, Saltimer and I are having this problem on the latest G4. You must test this on these machines!
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Anyone use Pro 52 and Direct connect? Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-10-2002 03:54 PM
Direct connect? Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2001 08:42 AM
Direct Connect keeps DisConnecting! Bryan Pro Tools TDM Systems (Mac) 3 08-03-2001 07:52 PM
Direct connect littlebear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-07-2001 07:54 AM
direct connect...how? Bryan Pro Tools TDM Systems (Mac) 2 11-30-1999 01:54 PM
