6085 error question about 6085 error mbox2 pro MacBook pro unibody 13". HELP
Question about a 6085 error and mbox2 pro
I just recently upgraded to a new unibody 13 " MacBook pro from the MacBook white. I started receiving 6085 FireWire errors when I started using the new computer. I found in another thread that mbox 2 pro and FireWire 800 hard drives are not compatible with one another. That said I was using the same drive as I did with the white MacBook. Is the error happening because the new MacBook pro has an 800 port as oppossed to the 400 port on the white mb? What is the issue and can or will it be resolved with software updates? What can I do on my end to fix this? |
Re: 6085 error question about 6085 error mbox2 pro MacBook pro unibody 13". HELP
Some folks have resolved this issue by using a Firewire 400 drive that has two Firewire 400 ports and a Belkin Firewire 800 to Firewire 400 adapter cable. Connect the Belkin Firewire 800 to Firewire 400 adapter cable from the MacBook Pro's Firewire 800 port to one of the the a Firewire 400 ports on the Firewire 400 drive and then daisy chaining from the drives other Firewire 400 port to the Firewire 400 port on the Mbox2Pro.
I know, you're asking what about my Firewire 800 drive? Save it for the day Digidesign makes a Firewire 800 interface. Or use it when you aren't using the Mbox2Pro. Apple really did Digidesign wrong when they removed the Firewire ports on the first unibody Macbook and Macbook Air and then stuck it to them again with just having Firewire 800 on the newest Macbook Pros, iMacs, and Mac Minis. At least on a Mac Pro, you can add a PCI card to get Firewire 400. Oh and on the 17" Macbook pro you can add an express card adapter for Firewire 400 too.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Just wanted to say thanks O.D. I had the same problem. Putting the MBox 2 Pro after the FW400 drive made it work for me. Hallelujah!
Sorry if I sound silly but when you say "drive" you mean hard drive? I searched in google for firewire drives but all I got was pci cards and external hard drives..
In that case we have macbook-> harddrive-> soundcard and this is supposed to work? |
Yes. That is exactly how it is supposed to work.
Obsidian Dragon
Ok thanks a lot for the answer! though I cant really figure how the driver could work through the hard drive, probably the hard drive acts like a simple bus in this case.. anyway thanks a lot!
I had the same problem, and this is what I did to remedy it too. It would be nice if there was a genuine fix for this, as it's not recommended to hook it up this way.
MacBook Pro 2.66 i7, OS X 10.6.3 Mbox 2 Pro Glyph GT 050Q HDD Pro Tools 8.0.4 |
Where are you reading that? This is a perfectly acceptable way of connecting those devices...
Are you saying that this is also a totally acceptable way of connecting the hardware? I may have misunderstood the information given, that's always an option.
The reason we gave the recommendation was mainly for 002/003 owners - who could turn off the unit without consideration for the drive attached. It was mainly to avoid that situation - though it's easily avoidable, just don't turn off the 002/003 while the drive is mounted. In the case of an Mbox 2 Pro, that situation is unlikely, as a vast majority of users run it via bus power, so it can't be turned off. |
-6085 error on MacBook Pro i7/Mbox 2 Pro | Banana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-03-2010 01:32 PM |
Unibody MacBook Pro vs. MBox 2 Pro (how I beat Audio buffer underflow -6085) | Arthur Nascimento | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-25-2009 09:40 PM |
Firewire error -6085 on MBOX2 Pro | meter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-13-2007 01:16 PM |
6085 error on G5 with mbox2 pro | burntnorton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-30-2007 11:46 AM |
DAE 6085 Error and MacBook Pro | MTSU Tech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-08-2007 10:20 AM |
