Keyboard shortcut for recording
This is an amateur question, but here goes. I have been used to working in Windows, and recently got my first mac. When using PT in Windows, I just used F12 for recording. This obviously isn't the same for the Mac, or there is something I'm not getting. I have went through all the shortcut settings as described in the manual, but still F12 only adjusts the speaker volume.
What's the trick? Is there maybe another key on the Mac, or is there no "one key" solution?
MacBook Pro 2.66 i7, OS X 10.6.3 Mbox 2 Pro Glyph GT 050Q HDD Pro Tools 8.0.4 |
Re: Keyboard shortcut for recording
Hold down the "fn" key and change your keyboard settings in your system preferences. Also, disable spotlight in your system preferences for the shift+spacebar option.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
If I read this right, there is no "one key" solution, like on the Windows version?
I believe I have disabled that Spotlight thing, at least what the manual said.
If you disable the F12 spotlight key command in system prefs then F12 will trigger recording in Pro Tools.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I believe I've already done that, hence my puzzlement. I'll triple check.
In system preferences, under keyboard, there is a box to check "to use F1, F2, etc keys as standard function keys." If you check that then pressing f12 will work for recording. When not using Pro Tools, you will have to use fn + F12 for volume when listening to audio on your computer.
If you have one of the keyboards with a numeric pad you can just push the number 3. If you're on a laptop you'd have to do numlock then push the 3 rhat I believe is on "L" or "."
Numpad 3 and Command+space will also start recording
Evan Click me... MacBook Pro 2.8 GHz intel i7, 16GB / OSX 10.10.5 / PT 11.3.2 / UA Apollo |
Keyboard Shortcut? | anackman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-02-2011 12:39 PM |
Does anyone know the keyboard shortcut for... | fancy_terry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-02-2008 07:19 AM |
keyboard shortcut | lightning ad | Post - Surround - Video | 11 | 03-17-2005 01:26 AM |
keyboard shortcut for... | lancebrwn | Pro Tools TDM Systems (Mac) | 2 | 09-17-2003 01:48 PM |
keyboard shortcut | dogpile | Pro Tools TDM Systems (Mac) | 9 | 01-24-2002 11:31 AM |
