Old 12-14-2018, 11:48 AM
Scott Stillwell's Avatar
Scott Stillwell Scott Stillwell is offline
Stillwell Audio
Default Pro Tools 2018.10 (or .12) suddenly won't launch
This just started today and I can't find a solution so far.
Launch Pro Tools as normal, the splash screen gets to the point where it says "Initializing Library Content" and then boom...error dialog. Message as follows:
Could not complete your request because Assertion in "/Volumes/Development/223020/ProTools/AAE/Source/AAX/CFicAAXWidget.cpp", line 851.
The error started when I was on 2018.10, and since I see 2018.12 is a bug fix release I've tried installing that...same issue after install.
Mid-2012 Mac Pro, 3.33 GHz 6-core, 48 GB 133 MHz DDR3, 1 TB SSD boot volume (Samsung 850 EVO). 10.13.6 patched current.
Any and all help appreciated.
Scott
Old 12-14-2018, 11:50 AM
Stillwell Audio
Default Re: Pro Tools 2018.10 (or .12) suddenly won't launch
Note - I've removed any recently-installed plugins from the system (the only things I can think of are Harrison's AVA EQ and Waves Shell, but removing it from the plugin folder doesn't seem to have any impact, so that's probably not it)
Old 12-14-2018, 12:01 PM
Richard901 Richard901 is offline
This Avid Knowledge Base article might help:
https://avid.secure.force.com/pkb/ar...FAQ&popup=true
Pro Tools 2023.9
Ventura 13.6
Old 12-14-2018, 12:11 PM
All in that note linked above.
Most common cause is having the wrong device selected as playback engine. Especially having an aggregate device that has no output or selecting say Built-In Input on a Mac as the playback engine.
Why Pro Tools does not detect issues like this and offer a user understandable error message is beyond me.
Old 12-14-2018, 12:33 PM
Stillwell Audio
Not sure how it got switched back to Pro Tools Aggregate I/O, but that was the issue, sure enough. Held down 'N' to get the playback engine dialog, then reset it back to my Babyface Pro. That did the trick.
Thank you both kindly!
Scott
Old 12-14-2018, 12:38 PM
Great!!!
Glad you got it working.
Pro Tools 2023.9
Ventura 13.6
Old 02-18-2021, 08:38 AM
mixedbywade mixedbywade is offline
So Im also having the same issue with 2018.12. It crashes as the session is about to open.. I have deleted preferences, and also changed the playback engine to built-in-output before trying to open a session. Nothing is working.
Release
-----------------------------3AB50C2A4431B782
Content-Disposition: form-data; name="upload_file_minidump"; filename="minidump.dmp"
Content-Type: application/octet-stream
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 Randroo Pro Tools 2018 7 05-07-2018 08:11 AM
Pro Tools suddenly taking 10 minutes to launch-help? amiller Post - Surround - Video 7 12-30-2011 10:18 AM
Suddenly can no longer launch Pro Tools twillner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-14-2009 05:19 PM
Help! I suddenly can't launch Pro Tools! Pamela Z Pro Tools M-Powered (Mac) 11 11-06-2007 08:53 PM
Mbox wont launch suddenly-just like that! 1977 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-19-2005 02:33 PM
