Old 06-24-2014, 09:21 AM
pihahiroth's Avatar
pihahiroth pihahiroth is offline
Default 003 Rack+ with Focusrite ISA 430
Hi folks,
Well, I´ve been using my DIGI RACK 003+ with the channel strip Focusrite ISA 430. It sounds very nice and it adds some very warmth character, but also is so clean.
Until now I only been using when I record some guitars and vocals, with the input of the focusrite mic/inst/line input. Then from the focusrite I send the signal via ADAT lightpipe cable to the Digi Rack.
But now I want to use the focusrite channel strip in my mixs, so How do I do that?
How can I send the signal of my mix from the Digi Rack to the focusrite to be process and then send it to the digi rack back again?
Very greatful for the help!
Dont Stop for Nothing, its full speed or Nothing!
Old 06-24-2014, 12:11 PM
Default Re: 003 Rack+ with Focusrite ISA 430
Isn't the 430 a single-channel box? There's no simple way to process a stereo mix thru it. With a 2 channel box, you could set it up as a hardware insert(the manual spells that out).
Old 06-26-2014, 04:28 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi pihahiroth,
This sounds like you would like to create a Hardware Insert to use the 430 to process a single track with EQ and compression. Is this correct.
Here is a video on setting up a Hardware Insert with Pro Tools:
https://www.youtube.com/watch?v=557aAvY3R84
This would likely be done with analog Ins and Outs, though this would depend on the interface you are using and if Pro Tools can select a different Input and Output Number for the Hardware Insert.
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 06-30-2014, 09:33 PM
pihahiroth's Avatar
Hi Katherine, thanks for the answer... I´m going to check that possibility... I know that the ISA has multiple kind of conections and use.. Im just trying to squeeze the best of it...
Thanks!
Focusrite Liquid Sapphire 56 into 002 rack paulsadler Third Party Interfaces 3 11-24-2013 01:37 PM
Pro Tools 10, Focusrite Pro 14 and Eleven rack s1owens Third Party Interfaces 4 09-26-2013 01:43 PM
Focusrite VRM Box with PTLE 8 002 Rack George Siede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-15-2011 06:44 AM
connecting focusrite octopre to 002 rack paulfof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-23-2005 01:42 AM
Focusrite ISA 428 "Pre Pack" and Digi002 Rack? Dan M. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-02-2004 04:39 PM
