Old 09-03-2021, 04:15 PM
Samba Samba is offline
Default How to make midi notes look big
I know how to make the midi notes look bigger.
What I don't know is this - When I press E, I automatically view midi in full screen. However, the notes are really small and I have to manually make them bigger every time so that editing is possible
The question: Is there a way to make the midi notes bigger by default? This way, every time I click E to go to full screen, the notes are big enough for editing
Old 09-03-2021, 04:46 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Re: How to make midi notes look big
Search in the Shortcuts document for "MIDI Zoom"
Vertical zoom in or out (MIDI)
Mac - Command+Shift+ ] or [
Windows - Control+Shift+ ] or [
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 09-03-2021, 05:29 PM
Awesome! Thank you :)
Do you know if it is possible to do what my question asks? To set the notes to be always a bigger size when opening up full screen? Currently the default does not cut it
Old 09-04-2021, 04:26 AM
Once you set a note size for the MIDI editor it should stay that size. Does on my setup.
Jack
QAPLA!
Old 09-14-2021, 06:08 PM
It never does on mine.
I have to constantly adjust the midi note size as they always appear tiny in Full screen (From pressing 'E')
I'm on PT 2020.5.0
Old 09-14-2021, 06:10 PM
Does should = designed like that? That would indicate my version has a bug?
Old 09-14-2021, 06:54 PM
Stays the size I set once. Unless I delete the preferences. What exact PT version and operating system are you using? PT 2021.6 on OSX 10.13.6 which is an unsupported combo but it works just fine for me.
Jack
QAPLA!
Old 09-14-2021, 07:14 PM
PT 2020.5.0
OS 10.14.3
2018 Macbook Pro
Old 09-15-2021, 04:48 AM
PT 2020.5.0
OS 10.14.3
2018 Macbook Pro
It could be your combo of OSX and PT as checking the compatibility page it shows PT 2020.5 as being compatible with OSX 10.14.6. You may want to try updating your OSX install - grab the combo updater and use it (after you make a bootable clone of your system).
Jack
QAPLA!
Old 10-12-2021, 02:09 PM
I've just wiped my laptop.
New specs: Big Sur 11.6 & Pro Tools 2021.7
The problem still exists. Midi notes always look small when in full screen.
Does Avid actually provide a way to set this so it's able to be set? Or is it a luck of the draw?
Make midi notes fatter Samba Pro Tools 2020 4 12-09-2020 10:56 AM
How to make notes to a each playlist? Sir Hannes Getting Started 4 09-14-2018 07:51 AM
Quatize make short notes Shasho macOS 1 07-11-2013 09:13 AM
Make MIDI Track Notes Bigger bugnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-12-2008 02:47 AM
Hey, why DIGI make midi notes flat in 6.7...??? Valentino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 12-04-2004 09:19 PM
