MIDI volume changed randomly
Did anybody have the same issue.
I have it the first time with Kontakt 4 in PT 10. I thought that it was Kontakt 4 so i updated to Kontakt 5. In the same session it doesn't happened again but in another session right now it pulls the volume of the instrument the half way down. Just after 2 min of playback. And now its was the mini grand from avid. so it seems its not wired to NI. I will try now to set an automation and see if it will happened again but is that a known issue? Thanks |
Re: MIDI volume changed randomly
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Thanks for your quick response but there was no automation. i checked that twice.
it happened every time on a different beat. e.g. by 16 beats...sometime on beat 4 sometime on beat 7 sometimes without. now i did the test and put a fix volume automation on the plugin midi level. it seems to fix that issue. its no really fine but i can live with that work around till 10.1/2 for native users |
It would be best for you to troubleshoot and try to sort it out.. lest it follow you along to the next version.
don't know why you mean thats no bug (only why yuo don't have it or never heard about it)...
but its still there in some session without any automation. it's sometimes comes up even in an clean new session... anyway. if someone else had that happened ("issue"). just write a static automations for that whole midi-part/song. that works for me now. |
Unplug your USB/MIDI keyboards.
Sometimes it comes from a defective pot or fader of the keyboard. |
Midi Randomly Changes Pitch In Pro Tools 10. | ZiviMusic | macOS | 5 | 02-05-2015 03:26 PM |
Track volume randomly drops | jonnytrip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-02-2011 01:46 PM |
PT 8.0.1 edit volume line viewing changed | modulo2008 | Pro Tools TDM Systems (Mac) | 114 | 09-10-2009 07:38 PM |
Midi tempo changed when I exported midi???? | Jim Don | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-02-2007 10:50 AM |
"Volume" Increment In "Large" View has Changed | Infa | Pro Tools TDM Systems (Mac) | 1 | 07-18-2004 05:48 AM |
