Access Violation Error...
Never seen so many of these in my life.
I get them every time I open my Session Setup Window "CNTRL+2" or when the "Spot to Track" window pops up and sometime also says "divide by zero" error along with it it does it on every project unless the project has NO tracks in it for some reason. any ideas anyone? I've un-installed and blew out the prefs with no luck Vista 32 SP1 PTLE 7.4cs5 |
no one else ever see this?
Access violations can be caused by quite a number of different issues, including but not limited to, out of date plugins, using illegal ("cracked") versions of plugins, compressed files on the hard drive, hard drive errors, unsupported hardware, etc.
So, some quick things to check;
If you could please post a plugin list using the utility in the Tech Support Folder, That will allow us to identify any plugins that you have that may be causing this problem due to being out of date or unsupported. It would also be extremely helpful if you posted details about your system as directed in the General Troubleshooting post at the top of the post list. More info about the session might help as well, if you know it (how many tracks? What sample rate/bit depth? any video in the session? etc)
PT LE 8.0.4 Access Violation Error | phaust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-02-2010 06:02 AM |
Access violation error, I don't know why... | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-13-2008 06:42 PM |
Access Violation Error?!!!?!????!!!!!!????? | jaaypeso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-20-2007 09:53 AM |
"Access Violation" error with LE 7.3 XP | RSSstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-05-2007 12:31 PM |
Access Violation Error | phdumas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2002 07:15 PM |
