Unable to locate 003
I am running Windows XP sp2 with a AMD Athlon 64 processor 3400+ 2.41 Ghz & 2.5 gb of ram. I have triple-checked my wimdows configuration setting suggested by digi and have sucessfully installed the 003 on a mac to make sure it wasn't the hardware. During installing PT LE 7.3 it recongizes the 003 but after installing and starting up pro tools it give me the error "unable to locate digidesign hardware, make sure your hardware is connected and turned on. Click "ok" when the hardware is ready. Any ideas what's going on? Why is it not recongizing the 003? Are there any other people having problem with Windows XP (sp2), Pro Tools LE 7.3 & the 003?
Re: Unable to locate 003
I would first check to make sure your firewire adapter is compatible with Digidesigns hardware. Some built0in firewire ports on motherboards are not compatible. Some add-on firewire cards are not compatible too. You should also check to update the drivers from the manufacturer if available. Secondly I would check the firewire cable. Are you using the same cable on the Mac as the PC? Firewire cables (and USB cables) have been know to fail without warning even though no physical damage or stress occur. I can'e expalin why but several folks got things to work after replacing the cable. I hope this helps.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I will have to check to see if those fireware ports on the pc or compatable, not sure how but good suggestion. Yes, the same cord i'm using now is the one I successfully used to install on the mac,it's firewire. It's fresh out the 003 box. Thanks for the reply!
Unable to locate hardware | diogo | FireWire & USB Audio Interfaces (Mac) | 2 | 01-07-2014 02:24 AM |
very sad unable to locate | chorus84 | Pro Tools M-Powered (Win) | 0 | 02-12-2011 06:07 PM |
PT9 Unable to locate hw | MikeLip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 38 | 11-07-2010 05:55 AM |
Unable to locate hardware | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-21-2008 11:07 AM |
Unable to locate hardware, help please! | Dahoud | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-11-2003 06:09 PM |
