Set end point for session
I am looking for a way to set an end point for a song. I want to bounce the file to the exact length every time without having to highlight the section I want bounced. I just want to know if there is a way I can set it so the file bounces to the same length every time without me having to think about it.
Re: Set end point for session
You can make a Marker that is a selection. Just Select it when you want to bounce and it will be the exact same length.
Mark Ettel C.A.S. |
as Mark said.
just about every session I've ever done has my "Mixdown Range" in Marker #40. it's simple muscle memory for me to be ready to bounce/track a mix. it's really worthwhile to make yourself a good template with Window Configurations, Memory Locations (for range, track heights, track show/hide etc) so that your sessions are always organized to your personal standard. Update any of them with Ctrl+Click. |
I also use a marker set to Selection for bouncing. Every bounce will be exactly the same length if you use this option.
the Session Setup window allows you to set your session start and length:
Devin Emke Audio Post Production Saturday Night Live, NBC |
Not at my system right now, but if I remember correctly that value you depicted is the minimum setting ! Who does a song or movie 6 hours long ?! |
right...but to the OP's point: you could set your session length to 4 minutes, or 64 bars, or whatever the length of the song, an then when you go to bounce you do not need to select anything on the timeline, or fire a marker. That was the original question raised in this thread, if I understood it correctly.
ok. try setting the session length to 4 minutes in the Session Setup Window, and post us the screenshot of your result.
Alternative: Just create an empty clip group on a mono track and whenever you want to bounce you just select that clip and you'll get the same exact selection down to the sample.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
This is what I have done for decades, and it works flawlessly. Bonus if you’re sending a track to sync to video, or stems, print a 1-frame 2beep at the beginning of the region and make it part of the Clip Group Sent from my iPhone using Tapatalk
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Running out of CPU power error always occurring at the same point in the session | nick133 | Windows | 8 | 06-17-2013 06:46 AM |
Importing Session from HD to LE Start point all messed up | drumbar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-23-2007 05:37 PM |
MARKING AND END POINT IN A PT 6 SESSION | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-23-2004 11:29 AM |
How do I adjust the Start point of my session | Hardnox | Pro Tools TDM Systems (Mac) | 3 | 11-21-2003 05:12 PM |
Session click recorded, zomm in, it's way behind Bar grid point, move it? | Jules | Tips & Tricks | 9 | 03-20-2000 04:51 PM |
