  #141
Old 01-26-2018, 12:11 PM
weezul weezul is offline
Default Re: Pro Tools 18.1 (12.9)
Originally Posted by Dizzi45Z View Post
So many great new features. My favorite so far is the new comping. Highlight a section of audio and press command shift up and down and it will automatically copy from other playlists that have audio in that section. Brilliant!
Thanks to the AVID team for your hard work.
I've just started messing with this, and the problem I'm getting is because of my current settings, scrolling through the playlists, creates a new playlist every time because i am essentially overlapping a previous clip, which creates a new playlist. So I thought I was scrolling through audio clips, but then I had 20 more playlists!! More time for me needed on it i think.
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
  #142
Old 01-26-2018, 12:15 PM
Preference settings.
Overlapped clips create a new playlist.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #143
Old 01-26-2018, 12:19 PM
I know that's the setting... I'm just saying, it seems dense to allow both. If i'm using the keyboard shortcut then maybe it shouldn't do it. But fiiiiinee I'll go click a single check box.
Pro Tools is done for. All these features and I still have to think a little bit
  #144
Old 01-26-2018, 12:51 PM
littlesicily littlesicily is offline
Default Re: Pro Tools 2018.1 (12.9)
Which Mac OS are u guys running w/ 2018.1 and feel is most stable?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
  #145
Old 01-26-2018, 01:39 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
High Sierra is working great here.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #146
Old 01-26-2018, 01:41 PM
Great to hear. Are you on the latest version of it? 10.13.3 ?
  #147
Old 01-26-2018, 02:33 PM
climber climber is offline
Just downloaded and installed it. Opened and played a couple of sessions I’ve been working on and all seemed to be fine. Tried the EQ curve display and it seemed cool, but no game changer. That said, I’ve been darn happy with 12.8.3.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
  #148
Old 01-26-2018, 04:09 PM
great to hear. Are you on the latest version of it? 10.13.3 ?
10.13.3
  #149
Old 01-27-2018, 04:21 PM
Rosco1969 Rosco1969 is offline
Track presets are great. One use I’ve found is that, if you have a mix template.. with all your plugs, routing etc... you can select all of those tracks in your template and save it as a track preset. I put mine in a folder called “mix” and called the preset “Mix Template” now I can just create a new track and call up my mix template with one fell swoop. Saves doing the import session data thing. Love it.
  #150
Old 02-01-2018, 12:27 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by amagras View Post
.101 .111 .121???
Problem is if this gets out of hand we could end up with 12.9!
You mean this whole merry-go-round for absolutely nothing? No. we can't have that!
And all this because a lot of folks are superstitious...there could be a huge drop in sales because of the number 13! I think 2018 is a very elegant solution indeed. Big kudos to the Avid marketing team!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Pro Tools First 2018.1 Missing EQ Graph panel Jakeman Pro Tools | Intro Discussion 5 02-06-2018 08:00 PM
Welcome to the Pro Tools 2018 forum DigiTechSupt Pro Tools 2018 0 01-25-2018 11:35 AM
Pro Tools v2018.1 Now Available DigiTechSupt Technical Alerts 0 01-25-2018 11:06 AM
Namm 2018 Pro Tools new hardware zavid General Discussion 14 11-17-2017 11:20 AM
