soloing a track in headphone mix?
hi there,
the other day I was recording vocals and the guy sometimes wanted to just hear his vocals... Is there a quick way to solo only the vocal sent to the hp cue.. Is it muting all sends and leave the vocal un-muted the only way..? Isn't that too much of a hassle? I know that I could send the vocal and the rest of the band to different "in between" aux tracks.. but isn't that a hassle too?? thanks a lot people |
Re: soloing a track in headphone mix?
Depends on the interface(hardware and software, if applicable). This is where experience and ingenuity will help you decide how to route audio to accomplish this. For instance, in my setup(DIGI003) I feed the main send to the headphone amp(so everyone gets the main mix) AND I can add(with AUX sends) "more me"(or more whatever) to each of the 4 headphone mixes. My dilemma was, how can I(the engineer) solo anything without interrupting the main mix(that is the basis for all the headphone mixes)? My solution was to add a send to every track(all at -0, all in Pre-fade, and all disabled and built into my session template). If I want to solo anything, I switch my monitor controller(Presonus Central Station) to a different input(what those sends feed) and enable the send(Ctrl-click). So, with a Ctrl-click, instead of a mouse click only, I can solo for me, without affecting the main mix feeding the phones. Figure out what works with your equipment
What I mean is being able to solo for the talent, not for me.. I don't if I understood correctly.. One way to do it would be to have selected all the tracks which I am sending, and hit option+shift on the send mute, and then unmute what I want him to hear. I jus thought about it... but it is a little slow.. Thanks a lot |
Be creative. You can create a mix of most tracks(with AUX sends or output assignment to a bus and route thru an AUX track. Send the AUX track to the phones as a mix. Then you can mute the AUX track to remove everything from the phones except the 1 desired signal(this is akin to setting a "mix-minus" feed). There's likely several ways to make this happen. You need to get the ol' brain bucket engaged
In reaper for example, I can use a single shorcut to solo the sends I want.. It jus took me by surprise that i could not solo ,but I guess , like all in protools, that you have to think ahead .... thansks a lot |
Well, Avid often tries to emulate how a real console works and I have never seen a console with this ability. One thing to tuck away in you mind here is, if you have headphones fed from AUX sends, and you use Post-fader sends(which might be counter-intuitive at first), when you solo the track, all other tracks will be muted(for you AND for those on headphones). Not sure if that might be a useful trick
Lose FX when soloing track | RandyPokeda | macOS | 1 | 10-03-2012 09:02 PM |
Soloing AUX Track | ggrill | macOS | 4 | 12-08-2011 08:26 AM |
Soloing Track - Sometimes Weird | Jsswtpmp182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-19-2006 08:48 PM |
soloing track in a subgroup? | peterle | Pro Tools TDM Systems (Mac) | 2 | 11-29-2005 12:45 PM |
problem with SOLOING a track | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-04-2005 07:02 PM |
