Question for DUC users recording audio from Korg Triton.
Can someone give me instructions on how to assign my audio tracks from the Triton sequencer to the 6 individual outs on the Triton allowing Digi to record 6 audio tracks simualtaneously. I was in another studio once and did it, except I have forgotten. ( Just haven't needed to do it until now...Thank God for the Digi 001!!!)
Anyway, I know there are some expert keyboard players out there who have done it. Please enlighten me and I will be forever in your debt. Thanks Guys, Jeff |
Re: Question for DUC users recording audio from Korg Triton.
Bump
Easy...
First, push the menu button, then go to insert effect. Once on that screen, you can select the output of the track. You can select the individual outs, L/R, or the effects. Since there are only four individual outs, you will obviously have to select the L/R buss and pan those tracks hard left and right respectively in order to use 6 simultaneous outs. Hope this helps... Jason
- Jason |
Actually,
you need to be in Mutli mode, in multi go to midi track 1-8 and pick your instruments. then to assign them to the outs push menu and slide over to were it says bus then you get the same layout of 1-8 but each midi channel has its individual out put display. inserting effects would then be the next step. this is all pretty clear in the manual, but I hear you sometime you just cant figure it out. I spent aa week trying to figure out how to make multisamples velocity sensitive, i looked under every listing of velocity, but Korg uses the the term intensity for this not velocity pain in my ass ------------------ Switchcraft
www.Subglo.com |
USB MIDI Recording From Korg Triton Extreme | XLR | MIDI | 3 | 01-16-2006 07:23 AM |
** KORG TRITON USERS: "COMBI" QUESTIONS WITH PT | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-06-2005 11:52 AM |
Recording MIDI into Pro Tools from Korg Triton | Sean1212 | Tips & Tricks | 3 | 07-30-2005 07:40 AM |
Recording midi notes - Korg Triton & PT | 3inacipher | MIDI | 7 | 04-20-2003 06:06 AM |
What's the usual process for recording MIDI tracks in Protools, and Korg Triton? | Shan Plourde | General Discussion | 1 | 01-14-2001 10:54 PM |
