Logic Pro Appset not working
When using LPX 10.5, none of the softkeys work, they are blank. Tried loading the LogicX appset, still nothing. Any idea ?
I'm using the latest WS 20.1.0.5 on Catalina. Thanks |
Re: Logic Pro Appset not working
You should just be able to load them. Send me your Appset in a PM and I can try and load here
Hi Eddie,
I loaded the LogicProX Appset that was included in the S6 Master Module Install 20.1 |
I'm being told we don't include one. Did you add any of your own softkeys ?
No i did not add any of my Softkeys.
Baically, i installed WS 3.5 when i first bought the S6 years ago, then installed WS 20.1 two months ago. When i hit Load i see one LogicProX Appset and that's the one i used. Are you saying that LPX Appset that comes with the 20.1 installer does not include any softkeys ? |
Did you see any softkeys on the surface with the older version of Logic ?
Sorry i can't remember if the softkeys were present on the older version of LPX.
I've been on 10.5 since it came out. |
If you're on an older version of LPX, can you load the Appset from 20.1 and see if the Softkeys are there ?
We don't ship an Appset so unless you previously built one this would explain what you are seeing. You can always build on now.
I'm 100% sure i did not built any Appset for Logic.
And if i did not built any LPX appset, where did the LogicProX Appset i see comes from ? Also if Avid does not include any LPX Appset, how can it claims that LPX is supported with the S6 ? |
Master module Appset blank | Mishabou | Avid S4/S6 | 9 | 04-04-2020 06:43 PM |
Any way to Import a Page of SoftKeys from an older AppSet? | massivekerry | Artist Series | 3 | 04-01-2020 12:15 PM |
Merging Appset files | its2loud | Avid S4/S6 | 2 | 10-05-2018 08:11 AM |
Appset | dez811 | Avid S1, S3, Dock and Control App | 5 | 10-07-2017 11:03 AM |
Help ! Is Logic 4.5.1 & DAE 5.0 working for anyone ? | Deutschland | Pro Tools TDM Systems (Mac) | 1 | 03-22-2000 03:46 AM |
