Old 04-22-2017, 07:35 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default Can't manually add MIDI note to first beat of clip
When I try to add a MIDI note to the first beat of a MIDI clip, PT does not allow it. It allows me to add the note anywhere else -- just not the first beat. Even if I drag an existing note over, it just disappears when I get it to the first beat.
This seems to be an issue with the clip boundary. The clip begins at 13 1 000. If I position the note to 13 1 001, the note appears. If I move the note to 13 1 000, it disappears (and no audio is played).
The weird thing is that there already are other notes on 13 1 000. They came "prepackaged" from a drum loop. I'm just trying to add a cymbal crash to the downbeat. I should note that I separated sections of the drum loop, and the issue seems to be specific to where the separations occurred. I suppose I can reconnect the clips into one, but shouldn't I be able to add a note to the first beat of a clip? The separations are "clean" and are at nn n 000 for each bar, so I'm not sure what the problem is.
Old 04-22-2017, 07:55 PM
Southsidemusic's Avatar
Default Re: Can't manually add MIDI note to first beat of clip
Put it in slip mode or set the mode you are using to 1/4 or 1/8 instead of 1/16 default and see if that helps.
We had a similar problem on 12.6 HD but on 12.7.1 HD it works as it should so i forgot we had that weirdness.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-22-2017, 08:12 PM
strangeLoop strangeLoop is offline
I think this is part of the ongoing MIDI issues that we are all having. What I notice is that grid measured clips in sequence will overlap and sometimes the first note in a clip will disappear.
John Clavin
John Clavin - AKA: Old Horseface
Old 04-22-2017, 09:10 PM
amagras amagras is offline
Exactly, when I copy in grid mode a perfectly quantized clip the first note always disappear. This is unacceptable to say the least
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-23-2017, 12:26 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Absolutely unacceptable for any DAW to have these major flaws in very basic
operation. MIDI is an intrinsic part of this stuff, and I don't understand why avid cannot rectify these things!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-23-2017, 05:37 AM
Because they are focused (or at least that's what it looks like) on Pro Tools First now.
amagrasmusic.com
Old 04-23-2017, 07:33 AM
del cosmos del cosmos is offline
Because its way more important to focus on the very popular "Collaboration" feature. :P
Old 04-23-2017, 02:59 PM
lesbrunn's Avatar
Yeah, very popular except for the greater majority of users... Avid is absolutely unbelievable!
Old 08-05-2021, 09:31 AM
squidknees squidknees is offline
Sorry for shouting but its 2021 and this is still an issue!!!??? Wtf avid!!!!!!!!!!
Old 08-13-2021, 10:51 AM
Noemie Noemie is offline
Yes it is...
I also notice first notes that don't disappear visually but don't play, which is even more dangerous.
Pro tools used to be a great DAW, it's so sad.
MIDI Note not displaying exactly at start of beat? midnightrambler Pro Tools 12 35 01-10-2017 11:58 PM
Can't place MIDI-note exact on beat nothe Windows 0 10-22-2012 03:40 PM
MIDI Editor should hide notes note in clip melino Pro Tools 10 0 06-30-2012 02:36 PM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
