Re: Playlist Layout A Bit Random?
Playlist view is useless for comping anything that uses multiple tracks. Best to stick to comping the old-fashioned way.
If we go CUE001 and go for a loop rec. Then create a new playlist for more loops etc. . .all the takes will be jumbled up, meaning if the dial editor recorded good takes - he doesn't just end up opening all the playlists with Take 1 being top and Take 25 being bottom. All the takes are mangled. Even the .02 at the end won't mean anything as it'll only be .02 of random loops. |
you must start with .01 on the main playlist .. sort you are having troubles with this .. i know how F'd up they can be ..
So, what I've noticed in my experience:
You can reorder the playlist (bit not from the track list, stupidly) and correct the problem before continuing on by dragging the lanes around. If you do this, try to have the last playlist available as your active one. Keep the lanes closed at all times while recording. Make sure you're on the last playlist when you add a new one. If you open the playlists, switch the active one out, and close them, you're asking for trouble. Relative to how much I do with Pro Tools, I use playlists a lot, and this is just how it is. Ideally you could view all lanes from the tracklist, and reorder them there, where it would be super easy, but alas, the entire functionality is a bit wanting. Can't add multiple new playlists at once, can't cycle through them without using the pop-up menu, and also why are they called "playlists"? That has got to be just the worst name for this. But they're too useful to not use.
Half in my head, half out of my mind - jakay.ca |
A way to create a new playlist when re-recording over playlist section? | jschmidtiii | macOS | 2 | 08-13-2013 02:28 AM |
For anyone who is having the random white noise burst / random distortion problem | Philly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-23-2010 04:56 AM |
PCI Buss SPiking... random random....HELP!! | s0nguy | Pro Tools TDM Systems (Win) | 3 | 04-04-2006 09:36 AM |
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-13-2004 01:08 PM |
OFFICIAL!! Random mute bug not random!! | Gwyn ap Harri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 10-09-2003 10:27 PM |
