Touchscreen monitors???
The monitors I'm using are touchscreen enabled, but there's no way for me to get into the display settings within windows. Am I mising something obvious here?
Re: Touchscreen monitors???
my experience with touchscreens in winXP are very complex usually. i dont think venue will support it. but dont quote me on it. im not sure the hardware in the console will support it but im sure sheldon and the venue team will have a better answer.
Brian Lloyd FOH Engineer - In The Mood LIVE -Reality.exe corrupt. Reboot?- Venue SC48 Macbook 13" HP 2525TX Tablet Motion Tablet LE1600 Mac Mini 2.6 dual core with 1TB 4gig Ram |
Most likely the touchscreen needs its own set of software drivers in order to enable the full functionality. Installing additional drivers on a VENUE system is not recommended or supported, as they have not been tested and may lead to instability. There are touchscreens that are plug and play (don't require drivers), and some users have tried these with mixed success, as many of the onscreen controls are designed for use with a mouse, not a finger. Sheldon |
You need to use HID compliant touchscreen drivers wich emulate a mouse.
If I´m correct Venues OS is XP Embeded so any XP HID driver will do. Check out ELO or Nextwindow touchscreens for more info. Cheerz Robert |
The only function that is usable with touchscreen is shutdown :)
Sticking with the mouse it is then, cheers guys
I have gotten an ELO to work, but really VENUE/touchscreen is not all it is cracked up to be. I like the control surfaces too much =)
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Input from touchscreen? Not possible? | Peterjk | Artist Series | 23 | 06-13-2018 01:12 PM |
Touchscreen Mix Window? | Dirt_ | Pro Tools 9 | 4 | 02-20-2011 11:40 AM |
Anyone using a TouchScreen?? | DeNiro | Tips & Tricks | 23 | 03-13-2007 02:04 PM |
anyone using a touchscreen monitor with pt | samuelhenriques | Pro Tools TDM Systems (Mac) | 7 | 09-10-2002 10:12 AM |
touchscreen anybody?? | Jochen | Pro Tools TDM Systems (Mac) | 6 | 10-24-1999 12:32 AM |
