Old 12-01-2007, 08:00 AM
Tim Rector Tim Rector is offline
Default Moving midi notes
Hi, I'm fairly new to midi and I guess I have a two part question.I am confused when trying to change the location of a single midi note. And being able to move a note and change the sound as the location changes.
First. Trying to move a midi note when highlighting it the whole"loop"is highlighted and it can't be done.I can delete the note but when trying to use the pencil tool to replace it,it appears to be rendered unusable, (grayed out).
Second, can a note that is in a "loop" be transposed. example, (snare,cymbal,kick ) moving it to a different location on the scale? I have been able to do this if I use a controller triggering single notes.
Thanks
Old 12-01-2007, 08:03 AM
audiogeekzine audiogeekzine is offline
Default Re: Moving midi notes
you can just use the grabber tool to move notes up and down (pitch) or left and right (time)
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 12-01-2007, 03:42 PM
Yes I have tried using the grabber tool but right clicking it highlights the whole loop and will not allow me to move it.
Old 12-01-2007, 04:19 PM
accession accession is offline
Are you in notes view?
Have you ensured no regions are highlighted (so you don't end up moving several notes by mistake).
Then the grabber should work.
Also, check my signature for a link to the "E is for EDIT" tutorial that may assist you in streamlined MIDI editing in Pro Tools.
Transposing notes, you could highlight the note(s) and drag 'em to the new note, or use the transpose function (though trying to think it if permits transposing single notes while leaving other notes untouched).
Also did you ask if you can change sounds mid-sequence? Yes, via the program change view, then click along the MIDI track where you want the change to happen, and a Program Change window opens for you to choose the preset you want it to change to.
Moving Controller Data with Midi notes Swar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-29-2009 09:38 PM
moving midi notes Toefinger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2006 01:30 PM
Moving Very Short MIDI notes timdiggle Tips & Tricks 8 04-03-2006 08:31 PM
PT7 Moving Midi events to different notes bakerja Pro Tools M-Powered (Win) 4 01-28-2006 06:38 AM
Moving MIDI Notes Dog BBQ Pro Tools TDM Systems (Mac) 3 10-12-2000 06:02 AM
