Old 07-09-2018, 09:29 AM
DonaldM's Avatar
DonaldM DonaldM is online now
Default Converting VHS to Digital format
I have several older VHS tape videos - family stuff - that I want to convert to digital format for better preservation. What do you all suggest as the best way to do this? I'm not sure what software/hardware will do the best job for this. Thanks for any suggestions.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 07-09-2018, 09:51 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Converting VHS to Digital format
I had too many to go through, as well as a lot of 8mm that my parents had. I gave up trying to do it myself and sent all my media to a local company (Feathers). They captured everything in 1080 and delivered it all on a hard drive as individual QuickTime files. Not a huge investment but well worth the money for the time I saved and the stress relief.
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 07-09-2018, 04:11 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
What equipment do you have? Or have access to?
The following has been my preferred method for many years. I have always had the equipment but the decks and cables should be fairly easy to rent.
Connect a VHS or (SVHS) deck to a DV or DVCAM deck (Sonys are my DV decks by choice) and make DV copies of the originals. DV copies are the best analog to digital conversions from VHS that I have found over the years. For the most part they provide the recorded signal with a new stable sync track and record a (new) timecode track. (a great help if you plan to edit them at any time)
I then capture the DV tapes into a computer ideally from a DV deck with an Serial Digital (SDI) output at Standard Definition. To stay digital I use a cheap connector will change the SDI connection to HDMI connector. Then inexpensive video cards like Blackmagic's Intensity Pro 4K used to capture via the cards HDMI input. (Most video IO's that you may already have connected to Pro Tools machines for monitoring video would achieve this.)
I capture to the computer at standard def. Why? Almost all home TVs have better display upscaling from SD to HD than can be achieved with affordable SD to HD codecs. Normal TV's can be set to display the correct original VHS's 4:3 display aspect ratios. (4 by 3 or 16 by 9)
Andrew
Old 07-09-2018, 08:37 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
On the PC I think the easiest way is to use something like this:
https://www.bhphotovideo.com/c/produ...to.html?sts=pi
Drivers can be a pain to get it to work though.
On the Mac I used to use a DV converter box like this: https://www.amazon.com/Datavideo-DAC.../dp/B00009XV2L
And imovie or Quicktime Pro to capture.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 07-09-2018, 08:53 PM
DonaldM's Avatar
Thank you all for the suggestions. Much appreciated.
Pro Tools 2019.10
Old 07-10-2018, 03:56 PM
V5V's Avatar
V5V V5V is offline
Just don't use a Blackmagic Intensity Shuttle as the capture device. For reasons that Blackmagic considers valid, it won't lock to sync from VHS.
I use an old Canopus 110 that we used for video output from Pro tools way back when. Now it takes video in instead of spitting it out! It's connected to the Mac with a Thunderbolt to Firewire adapter.
Lorin Schultz
V5V Audio
Vancouver, BC Canada
Old 07-11-2018, 03:55 AM
dougdi dougdi is offline
I get great results with a Thunderbolt Intensity Shuttle playing back off a JVC HR-9800U into my 6,1 Mac Pro. I will need a tbc for some problem tapes though. The deck has its own tbc but it won’t help those tapes. From all comments I’ve seen ymmv depending on the condition of your tapes and the built in processing enabled on the deck. Best setup would be a pro deck with external tbc.
Old 07-11-2018, 12:48 PM
Originally Posted by dougdi View Post
Idepending on the condition of your tapes and the built in processing enabled on the deck. Best setup would be a pro deck with external tbc.
For me recording to DV has always solved the issues caused by poor quality VHS sources. (DV creates its own sync pulses rather than relying on the source sync)
Andrew
Old 07-11-2018, 02:40 PM
V5V's Avatar
V5V V5V is offline
Andrew
I don't know how the choice of video format can affect capture. Anything downstream of the VHS machine needs to know where the frame boundaries are. If the interface won't lock to the incoming sync you'll wind up with a perfectly pulsed recording of vertical roll!
Lorin Schultz
V5V Audio
Old 07-11-2018, 06:09 PM
Recording VHS playback to DV camera or deck facilitates a stable analog to digital conversion. If you just pass the signal through the DV device you may well end up with
the VHS's issues. Record it and you get a stable digital stream.
Bringing the DV signal into the computer via SDI or Firewire records a stable digital stream. My experience is that the DV devices produce the best results from analog VHS. (I have also tested with Beta SX, Digi Beta and HDCAM decks with and without TBC's between the VHS and digital devices)
In suggesting the method here I assumed DV devices would be more readily available through friends or rental than TBC's. Plus they are also easier to connect than wiring through TBC's.
FWIW I have used that method for years. It is my preferred method for inputting archived VHS footage to MC for broadcast documentaries.
Andrew
HTML code is On
Help needed with converting PT 10 to 9 format... elangab Pro Tools 10 2 06-09-2012 04:08 AM
converting wav format into MP3 mastermorris Tips & Tricks 10 02-02-2010 01:26 AM
Converting PTS files to WAV or another format Valkhorn Pro Tools TDM Systems (Mac) 2 11-17-2007 08:23 PM
Converting a SDII file from mac format to pc..HELP KemikAL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-05-2003 03:55 PM
Converting a SDII file from mac format to pc..HELP KemikAL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2003 02:55 PM
