Old 11-07-2014, 09:24 AM
dougdi dougdi is offline
Default Clip group bug?
Using HD 11.2.1 Native on MBP 11,3 and 10.9.4
When changing the gain of a clip group the group breaks apart. The bottom clip splits into a new group clip and the rest of the group keeps it's name. I'm certain it didn't work this way before, just noticed it. Anyone else have this problem? Is it a bug or a feature?
edit -
Actually, I find that if I change the group clip gain with the mouse wheel, it works fine!
Old 11-09-2014, 10:47 PM
cabreetoe cabreetoe is offline
Default Re: Clip group bug?
Just replying to say I too have noticed the same behavior. I just updated to 11.2.1 yesterday and have noticed every time I make a gain change to a simple clip group spanning tracks the group breaks. The top clip reverts back to the original name while the bottom clip shows the original name with a group number suffix. Also, I've noticed that the undo behavior has changed: undo the gain change and the group state comes back but the top clips gain is still at the level of the gain change. a second undo returns the top clip back to its original state but thats just going back to before the clip was included in the group.
How do you drag a clip and make it snap precisely to the clip to its left without it maxgain macOS 8 03-13-2018 10:55 PM
Separate clip/region with a group of drum tracks has a 2-3 second latency. broken81 Pro Tools 10 4 03-17-2014 06:55 PM
Clip Group import solution jjohns39 Pro Tools 10 0 08-22-2013 12:21 PM
Strange Clip LED Behavior. No Clip LEDs on PlugIns anymore ? innenhofstudios macOS 14 08-19-2013 11:29 AM
change clip volume for a entire group Talisker Pro Tools 10 2 03-13-2013 09:33 AM
