Old 06-26-2014, 02:26 PM
dougdi dougdi is offline
Default Save Copy in - not working PT 11.1.3
When I do a Save A Copy in in PT 11 I get the message
"Could not save a copy in "Copy of 062614 XXXX XXXXXX" because No such file or directory (2)"
I created a folder with the same name but I still get the same error. This is a huge headache obviously it makes it impossible to convert a PT11 session to PT 8 or 9. I might reload 11.1.2 for now.
Thanks in advance for any help!
Doug
PT 11.3
Late 2103 MBP 10.9.1 16G 500G SSD Retina.
Old 06-26-2014, 11:45 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Default Re: Save Copy in - not working PT 11.1.3
works for me so it must be something with your system.
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 06-27-2014, 03:58 AM
Maybe I should update to 10.9.3 ?
Old 06-27-2014, 06:29 AM
sw rec sw rec is offline
No problem with it here, either.
Old 06-27-2014, 07:08 AM
ronwasserman's Avatar
ronwasserman ronwasserman is online now
Doug
PT 11.3
I get this. It's because I've moved some audio file I imported or something of that nature. Close and reopen the session, I bet it'll have to search for a file or two...even the smallest clip and then you'll be able to do the 'save copy as.'
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 06-27-2014, 08:12 AM
Rich Breen Rich Breen is online now
"Could not save a copy in "Copy of 062614 XXXX XXXXXX" because No such file or directory (2)" ....
Try saving to a different drive. If that's it, you may want to try trashing all your volume/database folders.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-27-2014, 08:55 AM
tamasdragon tamasdragon is offline
Works fine here.
Couple of things to check:
1. permissions are right? (admin, etc.)
2. everything is in place in the original session (no accidently moved/deleted files)
3. enough room on the target drive (know it's obvious, but worth a shot)
4. delete prefs - retry
my blog:Tamas Dragon
Old 06-28-2014, 09:25 AM
Yup, fixing permissions took care of it! Thanks!
"Save Session Copy In..." not working properly Meads Pro Tools 11 2 07-20-2013 09:15 AM
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
Save Session Copy In Not Working Steve@ZooWest Pro Tools TDM Systems (Mac) 13 01-07-2007 03:12 PM
HELP! 'Save Copy In" not working properly in v.7 Sebastien Bedard Pro Tools TDM Systems (Mac) 1 04-06-2006 09:51 AM
"Save session copy in..." not working in 5.1 nerdlinger Pro Tools TDM Systems (Mac) 4 03-08-2001 07:28 PM
