Old 12-21-2011, 01:33 PM
digi003 digi003 is offline
Default TL SPACE REV unable to read impulse resonse PT10
I have just moved over the Win 7 64 and PT10.
I have installed TL Space Reverb but when I open it i first get a message saying no images and if i try open a preset i get "Unable to read impulse response sample"
As far as i can see all the presets have installed in c: program files x86, common files, digidesign, DAE, plugin settings
There is the usual TL files in c: program files x86, common files, digidesign, DAE, plug ins
And there is a folder called "Trillium Lane" containing a sub folder called "TL Space" with impulse Responses
I never add an issues when using win XP and PT8
Can anyone please advise??
Old 12-22-2011, 01:47 AM
Default Re: TL SPACE REV unable to read impulse resonse PT10
Any help please
Old 12-22-2011, 03:56 AM
lennieh lennieh is offline
You might have to import the IR libraries again, and if you are using presets that you saved previously, the IRs will now be in a different location because you are on 64-bit OS you have two Progam Files directories, Program Files is for 64-bit programs and Program Files(x86) is for 32-bit programs so your presets are now looking in the wrong place....
Old 12-22-2011, 04:04 AM
how do you import them?
So if i moved the folder called "Trillium Lane" containing a sub folder called "TL Space" with impulse Responses to
in c: program files , common files
Would that work?
Old 12-22-2011, 04:37 AM
Try it
I'm not at my studio at the moment but I think there is an import libraries button over by where you select impulse responses, then you just search for the folder...
Old 12-22-2011, 06:10 AM
I move the "Trillium Lane" folder that i suggested in my earlier post and it worked.
Now i have other issues with other digidesign plugs
Thats for your help
Space - unable to get the impulse responses, favorites, presets, images to work mesaone AAX Plug-ins 7 01-24-2014 03:53 PM
TL space impulse location Tom Swift 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-03-2007 10:14 AM
TL Space Impulse Responses GuyPicks Pro Tools TDM Systems (Mac) 4 01-26-2007 07:58 PM
TL space- Impulse Responses bmuth Pro Tools TDM Systems (Mac) 3 11-07-2005 11:09 PM
