  #21
Old 09-04-2010, 08:59 AM
dr sound's Avatar
dr sound dr sound is offline
Default Re: Equality for all post mixers
Originally Posted by dr sound View Post
It does map to the center section. I had DMG send me an installer that did map to the center section. I will get him to post it on his website ASAP.
Here is DMG 's reply:
The updated installer is here with a changelog: http://dmgaudio.com/dl/EQuality%20v1.09a/
I don't have a DUC account, so please can you post on my behalf?
I can't update the default installer just yet, since this version needs more extensive testing before I can declare it a release version.
Cheers,
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
  #22
Old 09-04-2010, 02:27 PM
minister's Avatar
minister minister is offline
Originally Posted by Nathan W. View Post
Saw the Q only went up to 50, Q10 is double that at 100. Nice graphical interface though.
You realize that the numbers in digital EQ's do not always translate. The numbers you quote are meaningless unless you provide their reference. There are many factors involved in creating an EQ, filter design, impulse, amplitude and phase response, Proportional or Constant Q, notch, bell, etc.......
As another illustration, with this EQUALITY, just with a right-click, you can switch from bell to notch, and yet the Q numbers remain the same! By the way, I think this is a handy feature. Setup and EQ, make some adjustments, but just need one notch along with all the others.
Trivia question of today :
WITHOUT looking it up, what does 'Q' stand for?
When I first saw it, it reminded me of the AIR EQ.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
  #23
Old 09-04-2010, 02:36 PM
Branko's Avatar
Branko Branko is offline
Originally Posted by mr.armadillo View Post
Just out of curiosity: What is it you don't like about Q10? For surgical I still like it al lot. I wouldn't want to boost anything with it though.
I don't like it because it distorts easily and in a very unpleasant way, which reveals a lack of headroom. I don't like notching with only 18 dB of available range. I don't like ringing artifacts at high-Q settings.
That's why I'm using Equium (and later Unequilizer or whatever is it's name).
Looking forward to testing this new EQ plugin.
  #24
Old 09-05-2010, 09:22 PM
postprosound postprosound is offline
Oh very good one Tom!
The Q stands for 'quality'. The higher the quality, the tighter the notch. Wasn't the story that the name was made by the guys at the BBC?
We, in post sound, are illusionists, not magicians.
  #25
Old 09-06-2010, 12:38 AM
bluesfrequency bluesfrequency is offline
Thanks Marti, I'm really looking forward to using this.
Carlos Sanches
Re-Recording Mixer
Audio Circus
Warner Bros. Animation
http://www.imdb.com/name/nm0760851/
  #26
Old 09-06-2010, 07:07 AM
Very nice indeed (not only the practical aspects).
For the analyser I´d prefer a sonogram display. Is way more helpfull when trying to remove HMI whine and buzz that are very hard to see in a regular analyser display. I used to open Inspector post an EQ for this. Would be great to have that built into Equality.
What is the final purchase license like? iLok?
Frank.
PTHDn 2019.10 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
  #27
Old 09-06-2010, 09:15 AM
tklaavo tklaavo is offline
Hi
I really like the interface of Equality, and the "gain/q interaction" slider is very useful, as is the spectrum analyzer.
But:
I did some test with other eq's trying to get nulling with same signal on 2 tracks with the other phase reversed and finding similar settings. I found out, that Equality has inaccurate frequency scale - I could almost totally null the signal with boost at 2 kHz on Equality and 2.181 kHz on Q10. My setting is:
Equality: digital setting, 6dB boost at 2000 Hz, Q=1.00
Q10: 6dB boost at 2181, Q=5.2
I used the same file of pink noise on both tracks.
This is not total silence, but the closest I could get at 2000 Hz
Similar inconsistency of frequencies was found with Digirack EQ3 and Waves RenEQ. 2K on Equality matches 2.18K on other EQ's
Also, if I feed it 1kHz signal from Signal genrator plugin, the analyzer shows a peak at around 910 Hz
A bug? Looks like it. Otherwise a great plugin, and who cares about the numbers if it sounds right...
I'm running PT LE 8.01cs2 on a G5 mac. 48kHz 24bit session.
Haven't tried other sample rates yet
Can anyone confirm this on their system?
T
  #28
Old 09-06-2010, 10:14 AM
minister's Avatar
Half Right.
It stands for 'Quality Factor'. Specifically, the 'quality' of the L and C network. 'L' stands for inductors ('I' was taken up already for current) and 'C' is capacitors. The better the quality, the higher the Q factor.
I don't know the the exact genesis of the term, if it was BBC, RCA, or Bell Labs, Lagevin... In the '30's, John Volkman worked for RCA and he was developing some of the first variable EQ's (as opposed to fixed, like an RIAA or NAB curve) for Motion Picture playback. My guess is somewhere around this time. But it could be BBC.
Frank.
Not iLok. You download a license install program. You double-click on it and it authorizes your copy of the plug-in.
Tom Hambleton CAS
IMDb
-Starcrash
  #29
Old 09-06-2010, 11:01 AM
minister's Avatar
Originally Posted by tklaavo View Post
Hi
But:
I ran a similar test. I put a 2k sine wave on a track and inserted several EQ's with Notch claims.
With EQuality with a Notch at 2k, there was no sound reduction. I dialed around and found 1850Hz reduced it more than others, but it did not disappear.
Similarly, SONNOX Type 2 could not make it disappear.
Each of McDSP B1, DIGI EQ III, and Uniquelizer notches make the 2k sine wave disappear.
Tom Hambleton CAS
IMDb
-Starcrash
  #30
Old 09-06-2010, 11:20 AM
FlorianE FlorianE is offline
Half Right.
as far as I remember:
Q equals center frequency divided by filter bandwidth.
So, for a notch filter at 1000 Hz, and a Q of 10, the notch bandwidth (3dB points) would be 100 Hz, i.e. from 950 Hz to 1050 Hz.
Cheers
Florian
HTML code is On
Avid Giving Protools Post Audio Mixers the FINGER!!! bloke Post - Surround - Video 18 08-27-2013 08:26 AM
Equality and PT10 HD digidub Post - Surround - Video 5 01-03-2013 04:17 PM
Changing Equality parameters causes PT 10.2 to crash garnoil Post - Surround - Video 3 07-06-2012 11:51 AM
DMG EQuality with D-Command ChrisBurdon Pro Tools TDM Systems (Mac) 0 02-07-2012 01:26 AM
Equality strange problem garnoil Post - Surround - Video 3 01-14-2011 01:14 PM
