Mac Pro, Finder wont search the system drive.
Running Pro Tools 9 on a Mac Pro with OSX 10.6.8. We have 3 drives in the machine. After putting all 3 drives into the "Privacy" list for Spotlight Search as recommended by Avid, Finder will not search the system drive? When you type a file name or extension into the search window, it says its searching but returns nothing. Anyone have this problem?
Thanks |
Re: Mac Pro, Finder wont search the system drive.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 Last edited by sunburst79; 03-29-2013 at 05:08 PM. |
Although NOT recommended I have never had the need to disable spotlight on any drives to achieve performance.. Try NOT disabling spotlight and see if you run into problems. If you do, try exempting just the audio drive you record to... And not the system drive... My guess is that you wont experience any problems
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
I am not sure why you are surprised, you turned off indexing, so spotlight won't find things.
I think Avid has mostly been recommending just disabling indexing on the audio/session drive. However I have certainly seen problems caused by indexing running on the boot/system drive and I recommend to anybody experiencing problems to just disable spotlight on all drives. Wether you have problems will depend on your system, drive performance (a good SSD is much less likely affected than a HDD) and exactly what you are doing, e.g. CPU and IO load, wether VI samples are on the system drive etc. Apple also changed how aggressively the drives are indexed, in current OS X versions its more gentle and avoids hammering the drives as much as older versions, the downside is it can take much longer to index a drive (days....). I forget when exactly this was changed. For finding stuff on the system you can avoid the need for spotlight at all by just being organized and using things like the UNIX find command to search for file names. Darryl |
SSD of course
BTW I went back and checked on emails I had swapped with some Apple developers a while ago and from that all I can tell is that somewhere between OS X 10.6.8 and 10.7.5 the spotlight indexing seemed to get significantly throttled. I'm curious if others have noticed this? I was actually grousing because it had got so slow (even on a fast SSD drive) even I did want to have it on a drive. So it may not mean much, but since the OP is on 10.6.8 he may have the older style more aggressive indexing (and therefore more prone to disrupting Pro Tools?). I don't know if they ever went back more aggressively in Mountain Lion.
Darryl |
Oliver |
advice !!!!!!!
Thanks for replies. Im new to Mac and of course you can turn off indexing in Windows and it will still search.
Thanks for recommending that app, I'll try it. Finder appears in many posts on Mac forums as a problem and cause of crashes anyway. Thanks Mike |
Mac OS 10.8 unable to finder search Isis volumes | TomLewis | macOS | 3 | 12-26-2013 11:32 AM |
Unable to Search a Network Drive via the Import Audio Dialog Box | LT_CJ | macOS | 4 | 03-07-2012 01:25 PM |
Hard Drive search times too slow? | IonicBreed | Pro Tools M-Powered (Win) | 8 | 01-12-2010 06:06 PM |
SFX Search System | trickypig | Post - Surround - Video | 9 | 02-23-2008 12:32 PM |
Finder quits during drive to drive copies. | Danglebox | Pro Tools TDM Systems (Mac) | 3 | 04-06-2001 11:46 PM |
