Structure Free's gone mad!
I'm running into problems with Structure Free on PT8LE Windows.
Loaded a drum set into it, but when I tried to play a file that worked fine in Xpand2, structure free was chopping it's own samples. Basically, it sounds like a polyphony problem, so bass drums are cutting off ride cymbals, snares cutting off hats etc. There's no polyphonic overlap. Tried messing with polyphony setting, but all it did was make it go crazy....the snare started randomly playing itself, even with everything in 'stop'.....muting and unmuting the patch in the Structure Free window stopped this. I see a lot of people talking about trashing prefs and databases, but not sure if that'll work in windows or where they're located or even f that is the problem. Any help greatly appreciated! |
Re: Structure Free's gone mad!
Wow...quite a response!
Is Structure Free just so crappy nobody really bothers with it? |
Not sure what the word is on a fix for Structure FREE - with all the new upgrades going around it would be nice, but AVID are soooo busy changing their name at present I'm not holding my breath. HTH Scott |
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
When I loaded Structure from VIRT pack, Structure Free menu still there. | dl0banter | Virtual Instruments | 2 | 06-12-2011 02:23 AM |
The updater for Structure on Windows fails to locate and update Structure LE | Top Jimmy | Virtual Instruments | 23 | 07-27-2010 08:40 PM |
Structure Free's not showing up as an insert | JaRu | Virtual Instruments | 1 | 09-20-2007 03:19 PM |
