Re: This is KILLING me!
Did you read through this thread? http://duc.digidesign.com/showthread...=230034&page=2 |
I still don't know the cause. I'd like to prevent it from ever happening again.
I had a session to finish and I didn't dick around with the playback engine again after the playback bug stopped. I just did what I had to get through it. Why would the click plugin stop working after running the tech support utility option 2? Why do I get different results from using the tech support utility, and deleting prefs and databases manually according to the troubleshooting faq? When is database and preference trashing recommended? -after installing new/different hardware? -after installing new plugins? -after a version update? -after a cs update? -only when erratic behavior occurs?
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
By different results, I mean running the tech support then reopening a session has all the same preferences as before. It doesn't appear to do anything most of the time.
I run it from desktop/downloads/techsupport utility should it be in the Digidesign folder? If I manually delete the files I see a change closer to as if I had just opened PT for the first time. the play/stop thing happened again last night in a new session.
#16
The play/stop bug is still happening.
I will trash prefs again and delete prefetch
#17
Play/stop thing doesn't seem to be happening now, at least at max buffer settings.
Now I'm getting -9129 and -9093 errors if I open a plugin during playback, which makes mixing impossible. I've tried setting processor scheduling to Background services I've set windows appearance to classic no change. I've changed it back because I can't have it looking like [bleep][bleep][bleep][bleep] for no reason. what other options do I have? -I think RAID is disabled in BIOS -I need my internal soundcard for music and skype. -adjusting the paging file? Currently min=2046 max=4092 on C drive only.
#18
When did this start being a good idea?
#19
This combo seemed to fix 99% of my playback troubles.
Although every now and then have to delete prefs, annoying.... If you have an NVidia graphics card use the Avid certified driver for it here: http://www.nvidia.com/object/avid_cert_drivers.html At the same time trash Pro Tools preferences. Restart, cross fingers and toes. |
#20
Well maybe it's not, but I would think a quadcore pc with 4GB RAM should be able to handle a few programs running in the background. I'm not looking to get every last drop of performance here, I'm just trying to get a stable system that doesn't give me errors every 2 seconds. I'll try disabling some stuff in msconfig and see if it helps any.
11R killing PT | thegreyfox | Eleven Rack | 3 | 04-24-2012 09:34 PM |
Help My Mac Pro is killing me | Sebastien Richard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-20-2006 10:52 AM |
DP is killing me! | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2004 06:39 PM |
PLEASE THIS IS KILLING ME | mersisblue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 35 | 01-05-2004 10:40 AM |
am i killing anything??? | secondspassed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-14-2003 08:18 AM |
