upgrading to protools LE 6.9 on XP
Hello, Probably others have had the same problem... for some reason after i'm asked to uninstall the 6.7 version so that i can install the 6.9,and after restarting, it says I still have a valid version on my computer-No I don't!! But I can't update until my computer agrees!
Any thoughts, solutions would be greatly appreciated. i'm working on XP Pent 4, 2.2 ghz processor with an M-box thanks Chris |
Re: upgrading to protools LE 6.9 on XP
When you uninstall select 'PT LE' only
Reinstall 6.7. Fire it upand type in your product code. Then uninstall 6.7 but just 'PT LE' only. Now reboot and install 6.9 That should do it. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Thanks Shane, I tried but the same problem occurs.The computer 'thinks' there still is an installed version. Could it be it's reading the install disk?
C |
Hmmm... I had the same prob but thought the solution was my post above. It worked for me. Maybe someone else can chime in. I didnt use an upgrade CD though. I downloaded the 6.9 install to my desktop and went from there.
Shane
Shane, Thanks anyways. BTW I'm tring to update with the downloaded 6.9 version from the digi site as well.I have the 6.7 installer disk.
C |
I finally got it! There were all sorts of small digi files that didn't get trashed with the add/remove function. I used a 3rd party registry cleaner to get rid of those little buggers, and voila!
Cheers C |
Upgrading to ProTools 8 | wolfysi81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2012 07:27 AM |
Upgrading from Protools M powered 8 to Protools 10 | ab3514 | Pro Tools 10 | 0 | 01-12-2012 05:10 PM |
Upgrading from Protools M-Powered 8 to Protools 10 | charlottewrinch | macOS | 2 | 12-17-2011 08:05 PM |
Will upgrading OSX necessitate upgrading ProTools? | OBwan50 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-27-2006 01:24 AM |
Upgrading protools III? | friendlybunny | Pro Tools TDM Systems (Mac) | 1 | 12-05-2003 01:56 PM |
