Can't Open 6.4 LE sessions in 8 LE
Any ideas on how to open older sessions? I have upgraded from Digi 001, PT 6.4LE on a 10.4 G4 Mac to Digi 002, PT 8LE, on a XP (sp3) Dell 4600?
Thanks confused |
Re: Can't Open 6.4 LE sessions in 8 LE
Be sure when you save on the Mac that you check the box for Mac/PC compatibility.
So all files need to be saved for both formats.
Thank so much Tom |
On pre-ver.7 Pro Tools, sessions needed to be saved with a compatibility mode selected. You could choose this when you created the session, or later you could select Save Session Copy and then check a box to Enforce PC/Mac compatibility. Now if all the audio files were consolidated(so each track is a single continuous file), then you might be able to import just the audio into a new PT8 session(if the files are SD II, then PT8 should be able to convert them on the way in. Your best bet would be to find someone with a Mac and open each session and use the Save Session Copy function and enforce compatibility. When you installed PT8 on your PC, there was an option box to select to install HFS+ drive compatibilty and that would allow you to access the files from a Mac formatted drive.
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." | median | Pro Tools 10 | 5 | 10-01-2013 11:14 AM |
sessions always open with mix window track list open | jaglance | Pro Tools TDM Systems (Mac) | 2 | 08-03-2009 06:03 PM |
PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions! | chanlon25 | Post - Surround - Video | 4 | 03-03-2009 10:11 AM |
How to open PT 5.x sessions in PT 7.x | euge42180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-29-2008 08:58 AM |
PT5 will not open my PT4 sessions- S.O.S!!!! | Arteksound | Pro Tools TDM Systems (Mac) | 6 | 02-26-2000 09:01 PM |
