Old 04-29-2013, 02:25 AM
txrx txrx is offline
Default Pro Tools 10.3.5 Startup Error
I have a working 10.3.4, i uninstall 10.3.4 and install 10.3.5 it give me these error as attach.
Now totally cannot run Pro Tools .....
Old 04-29-2013, 09:39 AM
louieshowers louieshowers is offline
Default Re: Pro Tools 10.3.5 Startup Error
First uninstall Protools completely and then reinstall. Start there. Also, Run Protools as an administrator if you are on a windows machine.
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
Old 04-29-2013, 10:44 AM
YYR123's Avatar
YYR123 YYR123 is offline
10.3.5 should be an update bro
That means do not uninstall 10.3.4 - 10.3.5 goes right on top
And if you did - you need 10.3.2 which was the latest full installer - as far as I remember
Daniel
Old 04-29-2013, 11:41 AM
JGlen JGlen is offline
YYR123,
Just for your info, 10.3.5 is a full installer.
This is copied from the Avid Knowlwdge Base, Pro Tools 10.3.5 Info & Downloads.
Installation
Pro Tools 10.3.5 is a full installer
Avid recommends uninstalling your current version prior to installing 10.3.5 (reinstall the Drivers for your interface after a Clean Uninstall)
Pro Tools 10.x uses a single installer for both Pro Tools and Pro Tools HD. The installation is the same for both, only the iLok authorization is different
See the Pro Tools 10.3 Software Installation Guide for complete instructions
ADK Quad Pro, Intel Core i7 3770 IVB 3.5 Ghz, Windows 7 64
Seagate 500G Sata 600 OS Drive, Seagate 1 TB Sata 600 Audio Drive, 8 gigs of ram, 700 watt Coolermaster Silent Pro power supply. Apollo Quad Interface, Burl B2 ADC, Dangerous D-Box, UAD 2 Duo, Avalon 737, UA 610 MK II, UA 1176 LN Hardware, Focal CMS 65 monitors, and a bunch of other stuff.
Old 04-29-2013, 11:44 AM
YYR123's Avatar
Whoo hoo - op should be good then
For what it's worth they usually don't make the last dot release the full installer but that's cool
I would trash my prefs then try it again
Daniel
Old 04-29-2013, 11:46 AM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Yes, you right,
Installation
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 04-29-2013, 04:29 PM
Since there is also some update/change with ilok on this version, having your computer connected to the internet might make the difference between success and failure. My machine does not usually see the internet, but I happened to have it connected and my update went without a hitch.
Old 04-29-2013, 05:13 PM
Thanks everyone for the reply... as of now its running good.
The problem is not only i have to uninstall 10.3.4, i have to remove all the plugins, RTAS & AAX folder ....
So its going to take me some times to setup the plugins.
Happy PT'ing everyone ... cheers
Old 04-29-2013, 07:36 PM
You should have uninstalled avid effects as well.. The plugins should automatically be set up with the installation of 10.3.5
PT 10.3.8
Old 05-01-2013, 03:21 PM
zedhed's Avatar
zedhed zedhed is offline
Now that you have it running, it would be a good idea to make an image of your system drive to insure you against any future problems. It's far easier to reinstate an image than to have to uninstall/reinstall
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Pro Tools Startup Error -9514 frank1985 Pro Tools 10 3 12-05-2012 03:09 PM
Pro Tools LE startup error WindyCityUSA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-04-2011 11:33 AM
DAE Error on Pro Tools startup Johnjohnjohn Pro Tools M-Powered (Win) 2 06-25-2009 01:51 PM
Error message on startup of Pro Tools RFUSED33874 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-15-2007 07:43 PM
Pro Tools LE Startup Error bowser11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-23-2005 02:51 PM
