Please Help! Need to figure out CARD order in 9600
Okay, I have:
Audiomedia III,Samplecel II, PowerLogix Rapidfire USB/Firewire Card, an Adaptec 3940 UW and a Video Card. Question is... What order? DigiTest keeps telling me that I have them in the wrong order. Your help is appreciated. |
Re: Please Help! Need to figure out CARD order in
We have never tested/documented that combination of cards.
http://answerbase.digidesign.com/detail.cfm?DID=2011 documents a setup for PT|24 in a 9600. Using that as an example you could start with the display card in slot 0 followed by the AMIII, SCII, SCSI card, and then the USB/Firewire card. Please let us know if you experience any errors running with this configuration (DigiTest might still throw an error if it doesn't know what the USB/Firewire card is).
• linkedin •
Jeff's suggestion looks good to me. Digicheck always gave me errors so I just ignored it and never had a problem. I will say that I had a problem with a 9500 where it would only boot and work with the video card in the last slot. My old 9600 had the following setup and it worked fine. Top to bottom
Video AMIII Samplecell II Egosys 2496 Audio card Adaptec 2906 scsi Asante Ethernet Card My current 9600 has.. Video AMIII Tango Firewire/USB Egosys 2496 Miro DC30 Asante Ethernet Kevan |
HELP! Trying to figure out card order in 9600 | audiodepar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-09-2004 04:20 PM |
PCI slot order in my 9600/G3? Please advise for firewire card addition | Boom Chic | Pro Tools TDM Systems (Mac) | 22 | 06-18-2002 12:18 AM |
9600 Card order for PT III w. Fuse card? | ragbor | Pro Tools TDM Systems (Mac) | 2 | 02-27-2001 08:13 PM |
Card order for two vid cards in 9600 | Florian | Pro Tools TDM Systems (Mac) | 2 | 09-09-2000 11:52 PM |
Card order in 9600 W Mixplus and 13-slot chassis | houser | Pro Tools TDM Systems (Mac) | 0 | 07-23-2000 09:50 AM |
