Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-06-2019, 11:23 AM
musicman691 musicman691 is online now
Default Track presets and mute/solo remembering?
Is it possible for a track preset to remember a track's solo or mute status? I don't see that as an option in the 'what to recall' window. Or am I missing something? I'm setting up some presets where it would be nice if I could have the preset come up with a certain configuration as to solo/mute. Particularly solo safe.
Something I noticed when saving a preset that I previously worked on using the same name it doesn't ask if I want to overwrite the existing preset or not.
Jack
QAPLA!
Old 09-06-2019, 11:42 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Track presets and mute/solo remembering?
I have no idea, but why not open that template file (rename to .ptx) and make the changes, save, rename back, and try if it works?
Janne
Old 09-06-2019, 11:44 AM
henningaround henningaround is offline
Concerning solo safe it definitely does work.
Old 09-06-2019, 12:34 PM
It's not a template but a track preset which has a different suffix. Or are you saying to make the changes to the preset, save it as a template (.ptxt) and then change the suffix back from .ptxt to the track preset suffix?
Thanks. I may have missed something.
Jack
QAPLA!
Old 09-06-2019, 12:38 PM
That's what he meant, yes. You can just save any session as a track preset by changing the suffix and moving it to the track preset folder.
Old 09-06-2019, 12:56 PM
JFreak's Avatar
That's right. PT track preset is a session file that has .ptxp suffix. If found from right place it is nicely integrated to the system.
You should be able to freely edit the presets by renaming the suffix to .ptx and back to .ptxp again
Janne
Is there a CC/MIDI learn for track solo and mute? Sir Hannes Getting Started 1 04-13-2018 01:15 PM
Track Solo and Mute Not Highlighting seanmccoy macOS 4 09-25-2017 07:41 AM
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Why would one track not mute when another is in Solo Brad Gillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2007 02:44 PM
Solo/Track Mute Problem JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2003 08:19 AM
