Old 10-24-2016, 05:07 PM
AMIEL AMIEL is offline
Default Fresh Install for PT 12 HDX MacOS M Lion, Yosemite or Mavericks
I AM PLANNING TO INSTALL A NEW HARD DRIVE, A FREASH MACOS AND PT HD 12 WITH MY HDX CARD.
What is the Most Stable MacOS for Pro Tools HDX and PT 12?
Thanks!
Reuven Amiel
Mixer/Producer.
Old 10-24-2016, 05:32 PM
PMF Media PMF Media is offline
Default Re: What is the Most Stable MacOS for Pro Tools HDX and PT 12?
Tough call as there are LOTS of variables... mostly what plug ins/VI's you're using and how well the manufacturer supports a given version of the OS. I've been running Sierra for the past 4 weeks and love it! Pretty much no issues at all, BUT I did perform a clean (from the ground up) install of everything AND I'm not running a huge inventory of plugs and no VI's - Waves Gold, Serato P n Time Pro and that's about it. My other system (which uses a heap of VI's and a load more plugs) is still on Yosemite and running very well.
DetroitT's Avatar
DetroitT DetroitT is offline
All depends on your needs.
i.e. HD10 for old session updating required Mac OS 10.8.5
If you multimedia Mac then Mac OS 10.12.x build not supported but from a clean build using the App Manager HD driver is as stable as some others.
Key will be re-installing / updating all plug-ins and have enough memory with SSD boot drives.
More information could get you you more than a general layout as I've put forth.
Old 10-24-2016, 06:29 PM
I use my Pro Tools for Mixing, that is my Priority.
Mountain Lion was solid with Pro Tools 10...
But I do not know how behaves with PT 12
Thanks!
Reuven Amiel
Mixer/Producer.
Old 10-25-2016, 03:26 PM
anybody can share more info?
Thanks!
Reuven Amiel
Mixer/Producer.
Old 10-25-2016, 03:30 PM
Carl Lie Carl Lie is offline
10.10 works pretty good.
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 10-26-2016, 03:47 PM
Marsdy Marsdy is offline
I'm finding PT12 HD VERY stable in Yosemite 10.10.5.
Dave Marsden
UK
Old 10-28-2016, 05:19 PM
So people recommend Yosemite over Maverick?
Thanks!
Reuven Amiel
Mixer/Producer.
Old 10-28-2016, 08:31 PM
More info?
Thanks!
Reuven Amiel
Mixer/Producer.
Old 10-28-2016, 11:41 PM
simonyeah simonyeah is offline
Default Re: Fresh Install for PT 12 HDX MacOS M Lion, Yosemite or Mavericks
Maverick with PT HD 12.5.2. Rock solid. Have been struggling before with different combo. Won't change for anything.
Envoyé de mon iPhone en utilisant Tapatalk
Can't reinstall PRO TOOLS LE 8 with new macOS Sierra 10.12 [solved] Corinna macOS 52 03-24-2017 01:54 PM
pro tools 8 and macOS x 10.5.6? vdz415 Pro Tools TDM Systems (Mac) 1 12-18-2008 01:43 AM
MacOS X 10.5 aka "Leopard" - with Pro Tools? driver49 Pro Tools M-Powered (Mac) 3 10-22-2007 12:48 PM
MacOs X and Pro Tools, when? GunnarO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-26-2002 09:48 AM
Most stable MacOS Livewire Pro Tools TDM Systems (Mac) 4 04-08-2001 04:40 AM
