Old 02-11-2011, 01:57 PM
alarmstudio alarmstudio is offline
Default Behringer ada8000 major Delay issue
I have a digi002 protools version 8 hooked up with two lighpipe cables (in and out) to the behringer ada8000. My main mixing console is a mackie digital 8 bus D8B. The reason for this set up is that i can take 8 analogue outputs from the digi 002, and i use the behringer ada800 to convert the adat to 8 more analogue outputs. the problem is that on the 8 channels coming from the behringer there is a major, major delay. on the vocal lines the first syllable is misssing. the sound itself is perfect , it's just missing the first second or so. It's almost like there is a really high gate effect on the vocal. the same happens with any other instrument send via adat to the the behringer. I tried replacing the cables, different sampling rates, 44.1 and 48. I've set the digi002 to master, and tried it as slave. nothing makes a difference.
any ideas??
thanks!
Old 02-11-2011, 05:13 PM
Default Re: Behringer ada8000 major Delay issue
You might want to google this one as it sounds to me like an issue I read about recently. It seems that Behringer added a "feature" where the outputs self-mute after a certain amount of time passes with no audio going thru. The delay sounds like the outputs went to sleep and they wake up AFTER audio is detected(most ADA8000 users just use the inputs so they would never notice this). I wonder if the BLA mods on the ADA8000 address that? Might be worth an email to them
Old 02-11-2011, 05:40 PM
sunburst79 sunburst79 is offline
You said is not simple latency correct. The first part of the word is actually getting cut off. Not delayed?
Thats whacked.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-11-2011, 05:47 PM
http://behringer-en.custhelp.com/app...analog-outputs
Allbee is correct.
Scott
Core 2 Specs Page
Old 02-11-2011, 06:20 PM
Theres not exactly tons of ADAT to 8 channel output devices out there. Another is the Alesis AI3. But it inputs and outputs via 1/4 connections. If you have a XLR snake you probably want to find an older ADA8000 without this "Feature".
Scott
Core 2 Specs Page
Old 02-12-2011, 02:04 PM
CME CME is offline
Weird but good to know.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 02-14-2011, 04:41 AM
That's great, it all makes sense now....what a weird thing to do from behringer???
I worked around the problem, easily enough. I found if i had trimmed the audio to the point where the vocal came in i would lose the first word or two. if i left a bit of audio (even though it was silent) before the vocal it would be fine. I also discovered the fault is less obvious running protools at 48 khz and 24 bit. I wonder why that is, maybe because of the extra headroom. Any way thanks to everyone for helping me shed some light on this oddity!!
much appreciated
eelco
Old 04-05-2012, 02:30 PM
mfruet mfruet is offline
I have a BLA moded ADA8000 and it has the same "gate" issue. Has no delay at all, but a gate to mute the silence. I fixed it putting a signal generator with pink noise @ -70db directed to one of the ADA's outputs constantly. If the sound doesn't stop to geed it. it doesn't mute and you have no gate/ delay.
Cheers!
Behringer ADA8000 (BLA) JONK Pro Tools 9 14 03-14-2012 02:28 PM
Behringer ADA8000 kevinsimons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-18-2006 12:06 AM
Behringer ADA8000 stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 05-31-2004 01:40 PM
Behringer ada8000 hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-21-2003 07:01 PM
Behringer ADA8000 Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-17-2003 04:00 AM
