Old 02-26-2008, 06:33 AM
jazzdoc007 jazzdoc007 is offline
Default External Hard Drive for Backup
Question:
I am looking to purchase an external hard drive for purposes of backup. I am running Pro Tools 7.4 LE on an intel iMAC with dual 2.33 ghz processors and 3 gigs of RAM. I currently save all my audio on an external firewire 800 LACIE hard drive. Knock on wood, I have not had any issues with this setup. My question is this:
Do I need to purchase a firewire 800 external HD with the oxford chipset for my backup drive or can I use a firewire 400 drive or a USB 2.0 drive; also, do I need to obtain a drive with the oxford chipset for backup purposes.
I appreciate your input.
Thanks...
Paul
Old 02-26-2008, 06:44 AM
Phil Ogden Phil Ogden is offline
Default Re: External Hard Drive for Backup
So long as you don't want to run sessions from the HD i.e purely to transfer and back-up, then a USB drive should be OK.
http://www.myspace.com/philogg
Old 02-26-2008, 09:30 AM
docscholl docscholl is offline
Why is that?
For the record, I've opened sessions that were saved on my hard drives (either in Firewire 400 or 800) and edited, mixed and bounced tracks.
Is this the incorrect way to work on a session, and if so, why?
Thanks.
003+ Factory & Mbox 3
Apple powered by OS X 10.5.8:
iMac 2GHz Intel Core 2 Duo/4GB SDRAM (8.0.5LE)
PreSonus DigiMAX FS
Old 02-26-2008, 10:18 AM
citi citi is offline
I think you misread the post. He was speaking specifically about USB drives, not FW.
CiTi
http://www.checkonet2ent.com
External Hard Drive For Backup Or Allocation ReynaldoPena Pro Tools 10 5 11-13-2012 06:21 PM
External hard drive for backup of Mac & PC files firewired Pro Tools M-Powered (Mac) 3 12-07-2009 12:49 PM
External Hard Drive for Backup - Opinions? djcream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2008 12:13 PM
I Need a RELIABE External Hard Drive for Backup fooloof Pro Tools M-Powered (Mac) 1 08-14-2007 11:29 AM
Best external firewire hard drive for data backup? el biciclista Pro Tools TDM Systems (Mac) 2 01-14-2004 09:49 AM
