Old 07-30-2020, 05:43 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default Madi + omni
I need to track 50 inputs fed to me via MADI. I have 1 HDX card. Can I connect my OMNI to a port, then the MADI to the omni's expansion port and configure the I/O to use some OMNI analog and some MADI? Then use the other HDX port for the second MADI i/o? Make sense? With a MADI interface alone taking both ports I have no monitoring or way to feed a mix to the video peeps.
Make sense? Or do I need to get a second HDX card? Any way around that and have a couple Analog monitoring outputs?
TIA, Ainslie
(sorry if this has been covered ... )
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 08-01-2020, 06:39 AM
nedd nedd is offline
Default Re: Madi + omni
To get 64 channels MADI to Pro Tools, you need to connect both ports on your HDX card to MADI. If there is expansion port on MADI (I forgot) you could connect OMNI to that?!
Old 08-01-2020, 06:51 AM
AINSLIE's Avatar
There’s an expansion port on the Omni - I did find a previous thread that covered this. Seems like I’ll get 48ch madi if I use a port to expand thru the Omni. In my case I can work with that. I will find out Monday when I set up for the recording.
Old 08-01-2020, 07:10 AM
I think that can work, you connect one MADI port to second port on the card and other port to OMNI!
FS: HD I/O, MADI, SSL Alpha Link MADI SX, 7.1 TASCAM Monitor Controller, Lucid 88192. antonis Buy & Sell 6 11-15-2017 05:51 AM
OMNI with the MADI IF? Mitch Griffin Pro Tools HDX & HD Native Systems (Mac) 8 03-21-2017 02:08 PM
AVID S3 - OMNI IO - SSL Delta Link MADI IO japple Buy & Sell 0 02-10-2017 08:36 AM
Madi box and omni together 64 i/o SamZ Pro Tools HDX & HD Native Systems (Mac) 24 10-22-2015 11:32 AM
