Can you bounce in Half speed
Hi all, I have been using Shift Space to play at half speed for some time, but my question is, can you bonce when in this? Seems crazy that it gives you the option, but I have to record onto something else, and then record back to tools.
Any one any ideas, or have I missed chapter. Many Thanks E.N |
Re: Can you bounce in Half speed
You can use busses to another track and then do half speed record by using Ctrl+Shift+Spacebar. The other option would be to BTD at the normal speed and then use a utility like my Header Investigator to change the sample rate in the WAV file's header by a factor of 2... when loaded back into Pro Tools the file will play at the wrong speed.
Rail
make a bounce on half speed.. | montreal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 08-27-2018 05:29 PM |
Bounce at Half Speed | torquemada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2004 01:21 PM |
Bounce to Disk at half speed? | SteveGarman | Pro Tools TDM Systems (Mac) | 3 | 07-29-2004 07:11 PM |
shortcuts for half speed +dbl speed recoring | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-09-2003 02:48 PM |
Can you bounce to disk at half speed? | LATablette | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-21-2002 08:34 PM |
