Old 05-24-2019, 01:15 PM
chrismeraz chrismeraz is offline
Default Ctrl Key Doesn't Work
Weird, weird problem. The Ctrl modifier key works only with SOME commands since I upgraded to PT2019.5.
It DOESN'T work with the following commands (nothing happens when I push these key combinations):
Ctrl + A for Select All
Ctrl + Q for Quit
Ctrl + S for Save
Ctrl + Shift + N for New Tracks
Ctrl + = to switch between Mix and Edit windows
It DOES work for the following commands:
Ctrl + Tab to move to next track when renaming tracks
Ctrl + Mouse Drag for fine fader movement
I've tried trashing all preferences. Can you guys suggest anything else?
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-24-2019, 02:13 PM
Default Re: Ctrl Key Doesn't Work
Any chance caps lock is on (maybe the caps lock key LED is faulty)? I am not sure it will do this, but worth checking. (Try typing text into some other window/program).
Old 05-24-2019, 02:15 PM
Thanks Daryll. No, the caps lock works properly in other programs. So does the Ctrl key.
Even weirder update: sometimes my Ctrl key works properly in PT. In the same session, without closing and restarting anything, sometimes the Ctrl key will work and sometimes it won't.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-24-2019, 02:42 PM
I would pop up the Windows on-screen keyboard and confirm that Windows is seeing the key combinations as you enter them. Also try entering them on the on-screen keyboard.
I recently thought I was going nuts with problems with a Mac keyboard using an app unrelated to audio... we suspect Apple at some time changed some low level key event handling for the numeric keypad keys... anyhow found the issue and got a fix in the application (iTerm2). Did question my sanity for a while.
Old 05-24-2019, 05:48 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
By chance I was reading you thread and I realized my Ctrl + . doesn't work in 2019.5 to stop recording and delete take. Is this working in your system?
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 05-25-2019, 08:39 AM
Yes, Ctrl + . works for me.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-25-2019, 04:22 PM
abc1mce2's Avatar
Update:
Ctrl + . only works correctly if I don't have destructive record set as the record mode. In any other record mode Ctrl + . works as expected.
Don't know if this is the correct behavior so can someone else confirm if this one way or the other?
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 05-26-2019, 03:29 AM
Ctrl + . does not work in Loop or Destructive record. This is expected behaviour. You also cannot Undo recording in these modes.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-28-2019, 03:25 AM
Can anyone help me out? I'm still struggling with this. Not having basic copy and paste shortcuts is killing me, never mind switching between mix and edit views!
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-28-2019, 08:49 PM
abc1mce2's Avatar
Those shortcuts are working fine on my Windows rig...no problem whatsoever.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
192 I/O doesn't work with PT 11 HD djkikis Pro Tools HDX & HD Native Systems (Mac) 31 02-24-2014 03:08 PM
8.0.4 doesn't work GuitarMessiah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 07-11-2010 10:10 PM
Two New C24's Mic Pre #16 Doesn't Work!!! MARVINBASS ICON & C|24 11 05-08-2010 10:40 AM
New Toy doesn't work G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2006 01:49 PM
My two day 002 doesn´t work already!!! Punkest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2003 10:07 AM
