Old 02-18-2014, 12:27 PM
jfplumb jfplumb is offline
Default PT11 - UAD2 problems
After updating to PT11, I am having serious CPU issues when using most of the UAD2 omni suite. CPU overload doesn't seem to make sense considering all the DSP is on my two UAD2 quad Satellites??? Has anyone else had these issues with PT11 and UAD2 Plugs? I have seen the AVID set up guidelines and have my machine configured as required.
Any help would be much appreciated. My workflow is being seriously compromised.
If this is the wrong forum, I apologize. I don't post very often but am at a total loss.
MAC OS 10.8.5
Pro Tools 11.1.2
Harware is NATIVE HD Card, HD MADI > SSL MADI AX.
Other specs below:
Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.66 GHz
Number of Processors: 2
Total Number of Cores: 8
L2 Cache (per Core): 256 KB
L3 Cache (per Processor): 8 MB
Memory: 32 GB
Processor Interconnect Speed: 6.4 GT/s
Boot ROM Version: MP41.0081.B07
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5
UAD Software
UAD Software Release Version: 7.4.1
UAD GUI Library Version: 7.4.1 12-05-2013 11:59
UAD-2 Engine Version: 7.04.666
UAD Hardware
Number of Devices: 2
Device # : 1
Device Type: UAD-2 Satellite Quad
Hardware ID: 838af-30c9f-bb013-d168e
Serial number:
UAD-2 driver version: 7.04.666
DSP Bootloader version: 3.04.005
DSP Framework version: 3.06.41448
FPGA version: 0.13.44053
Microprocessor version: 0.18.004 AT
Authorization date code: 10-17-2012
Authorization supports up to version: 0.0
Device # : 2
Hardware ID: 358aa-20404-338d7-d683e
Serial number:
Host System Info
OS Version: Mac OS X
CPU: 2659 MHz (x16)
RAM: 2047 MB
Old 02-18-2014, 12:31 PM
Drew Mazurek's Avatar
Default Re: PT11 - UAD2 problems
Keep in mind the UA release is a beta and has many bugs.
I use PCI cards and don't have the issue you mention.
www.drewmazurek.com
Old 02-18-2014, 09:28 PM
Touchwood Studios Touchwood Studios is offline
My Satellite's are useless in PT HD 11 only my Octo card works - it could be a combination of the 2 together but yes beta has issues
Old 02-19-2014, 08:04 AM
sw rec sw rec is offline
Make sure to let Universal Audio know about this!
Old 02-20-2014, 06:26 AM
WinTaper WinTaper is offline
I have a UAD2 Quad. So far no major problems with PT11 - other than the latency of UAD plugins using AAX/PT11 is about 5 times the latency of the same session opened in PT10/RTAS (at the same playback buffer). Not a problem for me since I never track with UAD plugs...
-dan
Pro Tools 11.1.2 | Mac OSX 10.9.2
RME Ray-DAT | SSL Alpha-Link AX
Intel Core i7 990X @ 3.60GHz
Gigabyte EX58-UD5 rev 1.0
Old 02-20-2014, 06:41 AM
-dan
If UA could code their plugs to switch buffers, that would be amazing!! Lots of work though that I doubt they'll do.
www.drewmazurek.com
Old 02-20-2014, 08:55 PM
mrtomcat mrtomcat is offline
UAD 7.50 was released today. No more AAX Beta and the performance has dramatically gotten better.
Try that out
Old 02-20-2014, 09:13 PM
Southsidemusic's Avatar
Try that out
Agree 10000000% with this statement
Wayyyy better performance and the plugins just feel stable and solid so Good Job UAudio
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-21-2014, 10:50 AM
Thanks gang
Did a clean Mavericks install yesterday. New Solid state drive...Luck would have UAD2 v7.5 release on the same day. As soon as this game is over and I get into studio I will update and we will see. I feel lucky.
Go Canada.
Old 02-22-2014, 09:21 AM
UAD 7.5 AAX might be working better - but still adding 1024 samples of latency vs the exact same plugins running under RTAS/PT10.
Using a playback buffer of 128 samples in a session with a single track with a single UAD plugin (Neve-1073 / UAD2 Quad PCIE), PT10 reports 159 samples compensation, PT11 reports 1055 samples.
Clicking the UAD "Live" button (which actually runs the plugin natively, not on the UAD card) produces a latency of 31 samples on both PT11 and PT10. We can assume that the 31 samples is the latency of the plugin code itself, which is perfectly reasonable.
And the math adds up... Subtracting the plugin latency from the reported compensation in PT10 yields 159-31=128 samples (which matches the playback buffer) and 1055-31=1024 samples for PT11 (which does not match the buffer - but equals a very buffer-like looking value).
So it looks like UAD are doing extra buffering in their AAX-64 plugins ahen not running in "live" mode.
One other point of interest. In PT10 the delay comp changes to match the playback buffer, so for the above example if I change the playback buffer to 256, PT10 will report 287 samples of deplay comp - which when we subtract the plugin code, again matches the playback buffer (287-31=256). In PT11 changing the playback buffer has no effect on the reported compensation for UAD2 plugins (because its already maxed at 1024?)
I only use UAD plugs for mixing, so its not a big issue for me - but I was surprised at the large discrepancy between AAX and RTAS implementations.
-dan
Bunch of Problems with new PT11 install lightningad1 Pro Tools 11 3 07-10-2015 09:23 AM
Why is there so many problems with PT11 chaudes Pro Tools 11 23 01-19-2014 06:19 PM
PT11.1 /UAD2 Satellite & Digi002Rack greenetunes Pro Tools 11 6 01-01-2014 08:31 PM
Problems with pt11 and plugins aax vinagrepuro Pro Tools 11 6 09-24-2013 01:21 AM
Problems with PT11 (and 10) and 003+ kfisher Pro Tools 11 0 06-23-2013 12:03 PM
