Old 11-01-2011, 01:54 AM
37studios 37studios is offline
Default PT10 HD Native crashes while loading DigiRewire.dpm
I just installed PT 10 on my Mac OSX 10.6.8 machine, and it crashes while loading the digirewire.dpm plugin. I tried dragging over the same plugin from my other computer containing pt8, but it said that the ilok permissions won't allow it. so for now the digirewire.dpm is in my (unused) folder, but i need rewire to work obviously.
any suggestions? thank you!
Old 01-06-2012, 07:20 PM
haima haima is offline
Default Re: PT10 HD Native crashes while loading DigiRewire.dpm
i'm having a similar problem....
Old 01-06-2012, 07:26 PM
Craig F Craig F is offline
what are the permission on the file?
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-07-2012, 03:31 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I had the same problem.
Do you use it with SoundMiner v4Pro?
The thing is if you move away Rewire plugin from plugin folder, then everything runs smooth.
Also pay attention that Soundminer updated rewire plugin to their v.4
I contacted soundminer support.
They performed some fix and now my rewire works perfectly!
When you launch Soundminer for the first time it runs a script updating existing ReWire.
So I assume, generally it must be updated in order to use it in PT 10 with all apps working via rewire.
The thing is that there is no official update anywhere.....
So I think it's a Soundminer own codding for their v4 support.
Again, if you are not a SoundMiner customer then there is no solution yet for you. Avid should be aware of this problem.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2020.9 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 01-07-2012, 09:41 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Any rewire apps in 64 bit?
Reason 6, Reaper64, Bidule beta64.....
Might be:
1. Go to "Get Info" and check box "Open in 32 bit mode"
2. Some install loaded old pace drivers?
May or may not be the issue but just sharing some thoughts.
T
PT10 Crashes (access violation) when creating or loading 88.2/96Khz sessions JamesClark1991 Windows 5 11-15-2012 10:22 AM
HD-Native & PT10 crashes when flip is pressed on console Jaim Pro Tools 10 0 10-31-2011 08:09 AM
DigiRewire Plugin Crashes PT8 - help!! lemieux Pro Tools TDM Systems (Mac) 8 12-19-2008 04:11 PM
When loading PT 7.4.2 gets stuck on 'DigiRewire'...please help!! larsizzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-29-2008 05:09 PM
DigiReWire crashing pro tools on loading crizdee Pro Tools TDM Systems (Mac) 0 01-25-2005 10:28 AM
