Old 11-19-2002, 02:57 AM
lukeyy lukeyy is offline
Default Midi editing problem...
there is a very strange midi problem in PT - If I play something on my midi keyboard, quantize it after recording and then try to copy it, sometimes the first note of the block I copy gets lost while copying.... if I shorten the beginning of the first note a bit (in slip mode) I can copy the whole thing (with the first note...
but like this the first note is a bit too late (because i made it shorter at the beginning)
the same thing if I try to make regions out of a Quantized track and then try to copy them... some of the first notes get lost and others get pasted (as they should)
does anybody has the same problem - is this a bug in PT midi editing?????
[img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
Old 11-19-2002, 09:05 AM
mm mm is offline
Default Re: Midi editing problem...
My guess is that the first note(s) were a little early and in quantizing they were closer to an earlier 16th note (or whatever quantize note you selected) than to the downbeat of the section you are recording. If you slide it close to the downbeat then re-quantize it should lock up correctly and be able to be copied.
Old 11-20-2002, 04:06 AM
...it does not - if I take the first note and place it manually ( in quantize to bars mode) there is the same problem...
any other suggestions???
Old 11-20-2002, 09:14 AM
mm mm is offline
After you move it take a look at the event list to see exactly where the note on is.
Midi editing problem HKnight Windows 8 01-07-2013 08:39 AM
Midi Editing problem remusjacobs Pro Tools 10 3 10-12-2012 12:36 PM
midi editing problem bens10 Pro Tools 9 3 12-23-2011 04:48 PM
Problem with midi editing lydde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-27-2007 02:38 AM
Please help me with midi editing problem jef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2004 09:41 PM
