Old 01-13-2009, 05:46 AM
pmueller pmueller is offline
Default Video Camera Signal
Hi
We just got a Profile D-Show System using it in our recording truck, mainly broadcasting live concerts for Radio/TV. Just superb, thanks!
One first question; is there any possible way to feed our on stage control video camera signal through the venue system to avoid a separate snake for video only?
Many thanks for any ideas!
Patrick
Old 01-13-2009, 09:13 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Video Camera Signal
Hi Patrick,
What's the video signal format, and by "feed our on stage control video camera signal through the venue system" do you mean this signal would actually be connected somehow to the VENUE system, or run in a separate cable that's bundled together with the VENUE system's digital snake? If it's the latter then there likely won't be a problem.
Sheldon
Old 01-13-2009, 11:17 AM
Hi Sheldon
like others already comment. One reason to buy a venue is Digi's incomparable online support we already enjoy since Sound Designer II .
To explain my question: I work a lot with studer vista 5. There it is possible to connect the BNC video cable directly to the stage rack. The signal shares the same glass fibre cable, audio signal is transmitted both directions. In the mobile truck on the "FOH rack" a BNC connector is available to feed a normal video monitor. This is a fantastic feature. Same works with the optocore system /www.optocore.com/. On both systems I don't know if it's a add on or a integrated feature.
Best
Patrick
Old 01-13-2009, 11:58 AM
Hi Patrick,
Thanks for the kind words and further detail. There's no dedicated video "pass-through" connection on a VENUE system, but it'd be pretty easy for a systems integrator to build a rack panel that included an extra BNC connection, which then went into the same multicore snake (using a 3- or 5-conductor cable).
Sheldon
Old 01-13-2009, 12:38 PM
We bought a 6 way 150 meter snake as well and were surprised about the huge size and weight. We plan to use it for very special recordings only . Good idea, thanks.
Patrick
Slaving a video recorder/camera to PT HD transport? Recording synced video with audio sonicam Pro Tools TDM Systems (Mac) 5 02-18-2010 08:39 AM
OT: no video signal on startup jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-05-2007 09:58 AM
synch Pro Tools LE with video from DV camera?? doozerco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-21-2004 02:50 PM
Video Signal Through Audio Snakes? relaxo Pro Tools TDM Systems (Mac) 2 10-24-2003 08:49 AM
syncing Sony VX2000 digital video camera w/001? GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2002 08:37 PM
