Dynamics III causes PTLE to unexpectedly quit
I have a support request in to Digi for this, but maybe over the weekend someone else here can help:
Basically, Dynamics III has stopped working - anytime I try inserting any of the three plug-ins, PTLE quits. I've trashed DAE prefs and com.protools.plist or whatever it's called and I've tried repairing permissions. I don't remember what iteration of PTLE it last worked in for me - I haven't used it in a while, but I definitely have used it within the last few months since I got the Mbox 2 Pro. I'm also having some permissions problems with some Roger Nichols plug-ins at the moment as well where I get an 'unknown error' when I try to use them on anything other than an aux track. Don't know if the problem is related or not, I have emails into RND about that, and although it can be temporarily fixed by uninstalling/reinstalling the problem always shows up again next time I relaunch PTLE (ie, it'll work for one session). I'm on a Macbook Core Duo 2.0 with 2GB RAM, OSX 10.4.8. PTLE 7.3.1cs2, Mbox 2 Pro. All ideas/suggestions welcome! |
Re: Dynamics III causes PTLE to unexpectedly quit
HI,
since I also have the RND plugs myself and the EQ/DynIII plugs are working great on my equal setup: MB PTMP7.3.1. I could think of a problem with the installtion of PT itself. Did you verify that you have the correct intel/UB version of the plugs? the wrong version WILL cause problems. perhaps try uninstalling/reinstalling PT via the PT installer. be sure to check the Troubleshooting thread at the top of the forum. so far regs
last: PT11.3.1 |
All is UB, for sure. I've configured my system as suggested per the troubleshooting thread.
If I get time tomorrow though I'll try a PTLE reinstall and see what happens. |
OK - if I uninstall Pro Tools, are all my plug-ins wiped with it? How about plug-in presets?
HI
you can backup your plug-ins easily. There should be an Plug-in folder alias in the ProTools folder, just click it and copy the files to another location. or search for the RTAS folder via Finder. (it´s library> app support> digidesign> RTAS, I think) I did not have to uninstall the new PT7, so I don´t know what else will be removed. regs
last: PT11.3.1 |
Ok, I've uninstalled and re-installed. In between I used Applejack to repair the disk/fix permissions etc, but nothing's fixed.
One thing that concerns me is that the Uninstall Pro Tools program doesn't actually seem to remove everything. A few subfolders are left, with some files. Should this concern me? I did select 'Clean uninstall' but the Digidesign -> Pro Tools folders were left, and at the very least I think there were folders for MidiIO, Controllers, and the DVToolkit2.bundle file was still there, and possibly some others... |
HI,
sorry, the next way of testing would be reinstalling the system but that is always such a drag. You may perhaps try to download the DynIII plug-in seperately to make sure the installer wasn´t faulty. And make sure you have the latest iLok software if you still have trouble with the RND plugs. regs
last: PT11.3.1 |
Digi's responded now and we're trying to figure this out.
I did reinstall DynIII but it actually doesn't show up anymore in PT at all (since the reinstall) ... ??!!?? I'll see how this goes, but yes, a wipe/reinstall might be in order. As I'm on a macbook I can at least now have an excuse to upgrade easily to a faster/bigger HD... |
quit unexpectedly with 10.3.3 | Brandonn | Pro Tools 10 | 4 | 02-14-2013 05:19 AM |
Unexpectedly quit?! | GinGin3 | Pro Tools M-Powered (Mac) | 6 | 09-01-2007 11:30 AM |
Unexpectedly Quit - 6.4 | psdo991 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-01-2007 06:03 AM |
DFX Chorus causing PTLE to unexpectedly quit? | bassntreble | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-10-2004 04:29 PM |
PTLE "unexpectedly quit" any thoughts... | Red58 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-03-2003 02:23 AM |
