Focusrite VRM Box w/PT 9.0.2 - won't work thru S/PDIF
Windows 7 64 bit
Mbox 2 Pro (2nd generation) Firewire Pro Tools 9.0.2 I have my playback engine set to Focusrite. I can hear audio through the VRM Box when the S/PDIF cable is NOT attached- only the USB cable is connected from computer to VRM Box. When I connect the S/PDIF Out into the VRM Box S/PDIF IN (USB also connected) I get no audio from the VRM Box. Hopefully there is some setting I have not set. Ideas? Thanks. |
Re: Focusrite VRM Box w/PT 9.0.2 - won't work thru S/PDIF
I'm not entirely sure what you're saying, but have you made sure that you've gone to Setup -> Hardware, and then selected SPDIF instead of Internal?
Thanks for the answer.
I went into Hardware setup - it's set to "Focusrite USB ASIO Driver" Playback engine set to "Focusrite USB ASIO Driver". No sound coming out of the VRM box headphone jack. But if I disconnect the S/PDIF Out cable from the Mbox 2 Pro and also from the VRM box - I can hear output through the VRM box. |
Hi there,
It's my understanding that the SPDIF IN on the VRM box is only used in conjunction with another sound card. So, you would set Pro Tools to use your main sound card then route a signal from that via SPDIF to the VRM box and your headphones. Hope this helps. Kind regards, Rich |
I just got a VRM from Focusrite and when I try to use it in protools as my output pt tells me that I have a cpu overload
i tried every setting i know and no luck if I use either the mac built in output or my MOTU traveler PT10 runs great my mac is running at 30% or less so its not the computer I also tried this same setup in Cubase 4 and no problem and normally cubase is a pain in the neck with the resources has anyone had this issue |
I haven't tried it with Pro Tools as I have MP9, but my VRM box works as it should with Sonar and a Focusrite Saffire Pro 40. The Pro 40 is set as the output from Sonar. I connect the VRM box to the S/PDIF output on the Pro 40, and a PC USB port, and then start the VRM control panel.
PT MP9/Sonar X1 Ozone 5 Member of Nashville R.O.P.E. Assn. |
Focusrite ISA One Setup w MBox One S/PDIF Connection | Quinn9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-31-2011 08:56 AM |
S/PDIF work around on MBox2 Pro | user Julz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-29-2007 10:46 AM |
Getting s/pdif IN to work on my Mbox w/ LE 6.9 | tfalcone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-13-2006 07:57 AM |
Focusrite D2 and D3 doesn't work in 7.1.3 | mftorso | Pro Tools TDM Systems (Mac) | 5 | 01-15-2006 11:36 PM |
RCA S/PDIF input on 001 won't work! | btlguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-20-2004 05:31 PM |
