  #141
Old 02-21-2020, 02:35 PM
foxes's Avatar
foxes foxes is offline
Default Re: Sample Rounding Issue!!!!
Originally Posted by innesireinar View Post
I will take a look
Defo worth another look especially with Avid's ignorance to this so frustrating bug.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #142
Old 03-31-2020, 10:37 AM
Evermore Evermore is offline
Hello,
I don't do drugs but am I hallucinating? Did Avid just fix the issue with audio clips??
I have been testing the new 2020.3 update and have done numerous test with audio and tempos changes and all the audio clips are lining up on the grid perfectly.
At first I did my tests with the new Folders and thought it was the reason my audio was being copied and pasted perfect. Then I decided to try the test without any folders and to my surprise, all audio clips are still aligned perfectly to the grid at different tempos when copying,pasting and duplicating...big smile over here.
Can someone on 2020.3 check it out and do some testing to see if you get the same result.
One thing I can unfortunately confirm is that midi notes are still being shifted with and without folders when copying and pasting.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
  #143
Old 03-31-2020, 10:46 AM
foxes's Avatar
Originally Posted by Evermore View Post
Hello,
I have downloaded 2020.3. I'll install it later not over my 2018.7 and 2019.12 still on my machine and after some session work I'll report back particularly with midi clips as well.
  #144
Old 03-31-2020, 01:28 PM
Cool, sounds good. Thanks!!
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
  #145
Old 03-31-2020, 03:05 PM
Be aware that installing PT 2020.3 the workspace file gets changed and such that it won't work with earlier versions of PT. That means no more multiple versions of PT on the same boot partition at one time. Thankfully the installer warns about that before it happens.
Jack
QAPLA!
  #146
Old 03-31-2020, 03:39 PM
foxes's Avatar
Thanks, the installer does warn you. I have 2019.12 and several older PT version workspace .wksp files backed up after PTE website advised this some time ago.
  #147
Old 04-02-2020, 05:05 PM
take77 take77 is offline
After working on a session in 2020, duplicating a MIDI clip on the timeline via alt + drag still randomly copies the MIDI notes out of line with the grid.
So here is an easy solution that alleviates the problem when simply wanting to duplicate a section to another point in the timeline.
Simply open the clips list pane.
Then on the timeline, select the clip you want to duplicate.
By default it should highlight the selected clip in the list. If not, you can go to preferences and choose Editing>Clips list follows edit selection).
The clip you want to duplicate is highlighted & available to drag n drop onto the timeline wherever you want in your arrangement as often as you need.
Provided you are in relative grid mode, the selected clip can be dropped in at the start of the bar with the notes accurately duplicated in time so you can get on with your groove and arrangements.
I will note however, that this won't apply to copying multiple tracks of MIDI clips.
Hope this helps.
  #148
Old 04-04-2020, 05:33 AM
XJENSEN XJENSEN is offline
Thanks for the workaround. I think I'll try to adopt it for now.
However, this really remains an issue Avid should solve. Sooner, or later.
  #149
Old 04-04-2020, 10:43 AM
foxes's Avatar
Hope this helps.
Much thanks take77, I’ll try this as a workaround too, it’s still a lot slower than duplicate, repeat or alt+drag but much better than what PT does now. I really hope this ‘next best thing’ for now in midi arrangement editing is reliable with midi notes and clip lengths. And as XJENSEN has said Avid really need to pull their finger out and fix this ever so long standing and extremely frustrating bug.
Thanks again take77
  #150
Old 04-04-2020, 11:21 AM
innesireinar innesireinar is offline
Thanks again take77
They never will. Because we are only few users that can"t live with this bug. And I am really surprised how other users can
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 02:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
