Old 04-11-2021, 08:26 AM
Default Re: Updating a corrupted system from 2019.06 - what's stable for Catalina?
Originally Posted by Jeff ONeil View Post
Thanks Janne, I'm doing exactly what you're describing. I think upgrading the system to Catalina first and then backing up that is a good path to follow as well. As mentioned earlier in this thread all the libraries etc will be updated. I'll wipe the drive after that and install a Catalina. I have a few plugins I'll need to upgrade as well, running into the dreaded "subscription" payment plans. I'll suss out some options to replace what I have. I'm using and Apollo Twin so I have UAD plugins available at a reasonable cost.
Jeff
You should backup your drive first (before upgrading to Catalina) because something can go worn in the upgrade process. If it were me, I would skip the overwrite upgrade to Catalina step. I would make a backup and go straight to wiping the drive and installing (not upgrading) a fresh Catalina operating system. Then I would install Protools (the version you prefer - 2020.11 or 2020.12) and then the plugins and other applications.
The point others and I are trying to make is that upgrading your OS to Catalina without a reformat/wipe may bring your corruption issues with it. It is best to not do an "upgrade" type install over the current OS.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 04-11-2021, 08:29 AM
Jeff ONeil Jeff ONeil is offline
Good advice Obsidian, I"ve already backed up the HD so that step in your process is already done.
Jeff
Old 04-11-2021, 08:30 AM
Yes but if you have your music/photo/whatever libraries on your PT machine you actualy need to do the in-situ upgrade first to update the libraries. Only then go for the clean install.
Old 04-11-2021, 08:41 AM
Yes but if you have your music/photo/whatever libraries on your PT machine you actually need to do the in-situ upgrade first to update the libraries. Only then go for the clean install.
That was my original plan Janne. It won't take much time to do that. I have to get the plugin situation solved before I begin the process.
I use protools for VO work. I'm not an engineer, so ! contract out the creating templates for me for the various styles I use in my reads. My "guy" is busy this wknd so I'm delayed another week to make the full switch over. I could probably try and learn all the tricks and tips that you folks spent yrs learning but it's just not my area of expertise.
This will also be a busy week as ratings are on for US TV and my affiliate stations will be quite active.
Jeff
Is PT 2020 Stable with Catalina EarHole Post - Surround - Video 8 01-15-2021 12:00 PM
Pro Tools 2019 + Catalina legasafe macOS 134 06-24-2020 11:37 AM
Most Stable Pro Tools Version (Mojave/Catalina) Becharax Pro Tools 2020 13 06-12-2020 04:18 AM
