Re: CPU spike and errors on PT Ultimate/HDX system
Which version? Melodyne4 here without a hiccup
Latest 4.2.4
Just running an 8 track recording session. Been going 110 minutes now, buffer on 512. Could just be a weird thing in my system.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
We have Melodyne 4 installed, present on some sessions I tested today, not present on others. It did not appear to make any difference, once I had frozen audio tracks which had Altiverb instances, all sessions were able to run on the lowest buffer size for 20 mins or more with no errors or CPU spikes.
Mac Pro 5,1, 2 x 3.46Ghz six core Xeon, 64GB RAM, Mojave, PT Ultimate 2022.10, H/D Native PCie, Avid Omni interface. Mac Pro 6,1 12 core, 64GB RAM, Catalina, PT Ultimate 2022.10, 2xHDX cards & UAD Octo PCIe card in Sonnet TB Chassis, 2 x Lynx Aurora 16 interfaces. MacBook Pro 32GB RAM Catalina, PT 2022.10, UAD Apollo X4 |
I don’t think it’s melodyne anymore.
Really hard to nail down what’s actually causing the 9093 error. I can’t reproduce it and I don’t have time to put my plugins back one by one. I have disabled spindump and carrying on.
So my 4TB Raid 0 7200rpm spinners took a dump on me last night. Switched over to an SSD for now. Everything is blazing fast.
I think the one of the disks in the Raid array was failing and taking everything else with it. To be continued...
Yep -- that is the problem with RAID 0 that stripes for performance without parity information, so it has zero fault tolerance. Good riddance, SSD storage is so blazing fast now.
I work almost exclusively at 96k on my 5,1 MacPro HDX system and I have identified Sonarworks, Autotune, Soothe and Gullfoss as leading causes of CPU spikes at low buffer settings. Sonarworks is by far the worst. By far. I can have one single stereo master track in a session and it spikes at a buffer of less than 512.
FWIW I have not identified Altiverb as a source of spikes on my system.
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
Hey Will, that's really interesting. I used to have Sonarworks running on my master output but got so annoyed having to constantly turn it on/off (I would forget a lot of the time!) that I now have a dedicated Mac Mini running Sonarworks with a UA Twin running between my monitor controller and speakers.
Perhaps not the best converters but makes my life a whole bunch easier. Thankfully I'm yet to experience the Mac Mini to have a crash and for the speakers to output full scale noise. I should probably build in a fail safe for that...
Guys,
I think I may have cracked this... Mixing all day, different sessions, 128 buffer(!), session data importing, bouncing, recording, you name it. Not a single error...
Sent from my SM-G986U using Tapatalk |
A TON of spike and errors with 12.8 9093/72 | [email protected] | Pro Tools 12 | 38 | 06-29-2017 02:54 PM |
Buffer Errors (6086 and 9128) using Komplete 9 Ultimate Instruments | dunnaj | Virtual Instruments | 0 | 05-29-2013 12:14 PM |
Windows 7 Ultimate Freezing and BSOD Errors! | terrencej31 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-13-2012 05:05 AM |
Processor spike & system freeze-up is sessions | psalmeister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-25-2010 04:40 AM |
Multiple blue screen errors when trying to install/run PT 8.03 in Windows 7 Ultimate | WorshiperDj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-14-2010 02:50 PM |
