Old 12-02-2009, 09:18 PM
timerrin timerrin is offline
Default M-Powered 'load/start up' times
I'm just wondering what load/start up, or open, times others are experiencing.
I have ver 8.0.1 and currently have to wait for 5 to 10 minutes before ProTools loads. It was only about 3-4 min with before the upgrades.
You can imagine what happens if I forget to plug my midi keyboard in before start up - I have to start over again and wait...zzz
Cubase5 usually loads in a champion time of approx 10-20 sec. Same with another studio I work out of - PT8.0.1 on an imac loads in about 10 sec.
Other than the absence of IE8 does anyone have any suggestions?
cheers
Tim
Old 12-03-2009, 01:19 PM
DigiTechSupt's Avatar
Default Re: M-Powered 'load/start up' times
Does it seem slow in any particular part of the load process? You can see what's loading in the splash screen...
Avid Audio Tech Support
Support FAQ
Old 12-03-2009, 02:04 PM
It mostly takes it's time on the loading/finding plugins and some other dae functions. A bit like when I had IE8 on the computer but tools actually hung. It does load eventually. I'll have a good look at that tonight when I get home and try to document what it does.
Other than that it functions extremely well.
Old 12-04-2009, 08:59 AM
jmitchell1532 jmitchell1532 is offline
That seems to me like an unusually long load time.
Mine starts up in about 20-30 seconds.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 12-04-2009, 09:14 AM
hamsterMan hamsterMan is offline
Not normal by any means. My PT 8.0.1 will load in maybe 30 seconds. You should take out all your 3rd-party plugins (onto the unused plugins folder) and see if that has an impact on your loading times.
Old 12-05-2009, 11:45 AM
frantik frantik is offline
I've been told that certain, um, "demo" versions of plugs from a very well known plug-in manufacturer can cause this problem..
Trikome.com - blog
PTMP 8.0.1 // FLStudio 9 // WinXP SP3 // Axiom Pro 49 // Delta 44 // Mackie HR624 // AKG K701 // Emu 6400 Classic
Old 12-16-2009, 08:58 AM
Thanks guys...
It seems to take the most time 'looking for plugins' (slow) and 'loading plugins' (very slow).
It was still fairly slow straight after installation, before I installed any third party plugins.
It kinda looks like it did when I had Internet Explorer 8 on the computer, only it wouldn't load at all.
Old 12-16-2009, 02:57 PM
Can you use the Tech Support Utility from the General Troubleshooting thread to post a list of installed plug-ins? Maybe we can find the culprit...
Good idea to verify you're using the minimum version required for all installed plug-ins...
Support FAQ
Old 12-20-2009, 06:53 PM
jpumphandle jpumphandle is offline
I am a noob with Protools, but quick startup does not seem to be a strength. I have gotten used to it. My startup times run about 1.5 minutes before picking a project. (Windows XP, dual core pentium, 2GB memory)
Session Load Up Times Raoul23 Pro Tools TDM Systems (Win) 6 06-08-2013 07:32 AM
Tell me your load times using 10 oreo1 Pro Tools 10 0 10-23-2011 09:47 PM
PT8 long load times ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-14-2010 02:41 PM
Plugin Load Times?? NativeLuv17 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2009 08:05 PM
Protools LE 7.1 Load Times dpirrocco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-19-2007 11:24 AM
