Re: Eucon 3.6.1 S3 LCD font oversized?
Update for EddieJones:
Pro Tools | Control & Pro Tools | Dock now working as expected S3 working, but with enlarged fonts. Not a show-stopper, but certainly a bug that needs to be fixed. Expect better QA for the software from a $7000 Control Surface...
Shift Studios Computer: Custom Built PC Mobo: Gigabyte Aorus Z270X-Gaming 7 CPU: i7 7700k MEM: 16GB Corsair Vengance DDR4 3000 GPU: Gigabyte Aorus GTX 1080Ti Extreme OS: Windows 10 Pro x64 DAWs Pro Tools 12.7.1 Interface: Universal Audio Preamps: Focusrite, Universal Audio Outboard Processors: Universal Audio Control Surfaces: AVID S3, Pro Tools | Control + Pro Tools | Dock |
I have found the issue and yes it is to do with Windows Display scaling. The graphics on the surfaces are drawing by EuControl so if you have the setting zoomed this will cause the issue. In v3.6.1 we fixed the way this worked on the Mac and unfortunately some common code now effects Windows. Both OS's keep changing the way this works so its a cat and mouse situation.
I have engineering working on this right now but in the meantime the best work around I have found is to set the scaling of the offending Monitor to 100%, reboot and launch EuControl. Then set the scaling back to whatever it was (if needed). EuControl will have the correct font sizes until the PC is rebooted. As for the incorrect version message we generally see this when installing and uninstalling and part of the previous release was left behind. Also a complete power cycle including the iPad helps. Sorry for this, I'll keep this posted updated on progress. |
I can confirm resetting the scaling to 100% works here.
Thanks Eddie! |
Kindest regards, ~SHIFTstudios
Hi EddieJones,
Is there an ETA for the resolution of this issue? Having to keep scaling my display back and fourth is not the least annoying work-around. Kind regards.
#16
I don't have an ETA, but I can say that an engineer is working on it at the moment (Its a holiday here, but as soon as they get back in on the 5th he'll continue)
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 | deauditievedienst | Artist Series | 2 | 07-14-2021 09:33 AM |
Updated to Eucon 3.6 and lost all my custom Eucon commands | bassmagnetic | Avid S1, S3, Dock and Control App | 0 | 04-18-2017 10:09 AM |
Opening oversized PT12 HD session in non-HD PT12? | mjpatey | Pro Tools 12 | 6 | 01-10-2017 09:25 AM |
EuCon suddenly broken - Eucon client can not access the bonjour service | noiseboyuk | Artist Series | 0 | 04-12-2016 12:34 PM |
