Boom plugin
I installed the plugins that were on the installation cd, which included boom, but it's not showing up in pro tools. I am using pro tools 10 on windows 7.
Re: Boom plugin
The instruments are a separate installer, check the install disk, or login to your avid account where you'll find the instruments installer. Chris
Re: Boom plugin
Ditto. And then, once you're up and running, make a "Stereo Instrument Track," go to your inserts, then to "Instruments," and pick Boom. You should be making beats in no time.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
Re: Boom plugin
I installed virtual instruments from the CD that came with Pro Tools when I installed the plugins. But, Boom isn't showing up in Pro Tools.
Re: Boom plugin
http://avid.force.com/pkb/articles/d...ls-10-2-Update Click view available downloads near the bottom of the page and choose the appropriate one. |
Assistance with BOOM Plugin | myers570 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-25-2013 12:37 PM |
Boom | BobbyDazzler | macOS | 1 | 05-03-2012 12:25 AM |
Boom needs file Boom.big to run? | jonsimoneau | Virtual Instruments | 4 | 01-01-2012 03:40 PM |
Need help with BOOM!! | skatinblind815 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-12-2010 12:07 PM |
Boom | gil5280 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 04-03-2010 05:16 PM |
